Jurassic World Dominion 4K UHD - KEY NOT PRESENT error
IanW555
#1 Post by IanW555 » Sun Oct 26, 2025 3:23 pm
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO6P4EF0931
Highest AACS version: 76
Firmware version: 1.03
Disc Information
Label: JURASSIC_WORLD_DOMINION
Timestamp: 2022-06-21 17:33:09
Protection: AACS2.0/C v76
Data capacity: 87.50 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Saved AACS dump file as C:\Users\ianw/.MakeMKV/MKB20_v76_Jurassic_World_Dominion_AFD5.tgz
The drive is Verbatim 43888 and has been flashed.
I have downloaded and run KeyDB_Helper 1.0.1.6 and synchronised
Sorry, what am I doing wrong?
MrPenguin
Re: Jurassic World Dominion 4K UHD - KEY NOT PRESENT error
#2 Post by MrPenguin » Sun Oct 26, 2025 4:40 pm
IanW555 wrote: Sun Oct 26, 2025 3:23 pm The drive is Verbatim 43888 and has been flashed.
It looks like MakeMKV hasn't been able to enable LibreDrive, although I cannot see any obvious reason why not. Perhaps just try power-cycling your drive, waiting until your disk appears in Windows Explorer, and then start MakeMKV again?
IanW555
#3 Post by IanW555 » Sun Oct 26, 2025 4:52 pm
Thank you, I tried power cycling the UHD drive and rebooting the PC, but still get the same.
#4 Post by SamuriHL » Sun Oct 26, 2025 5:36 pm
Something is wrong with your drive then. Without LibreDrive being active, it's not going to work. As to why that's happening, if you've power cycled it, no idea. Whenever you see the Can't get VID... message, it means LibreDrive isn't working right.
MrPenguin
#5 Post by MrPenguin » Sun Oct 26, 2025 6:32 pm
IanW555 wrote: Sun Oct 26, 2025 4:52 pm Thank you, I tried power cycling the UHD drive and rebooting the PC, but still get the same.
Does C:\Users\ianw/.MakeMKV/_private_data.tar contain anything? It should include a file called sdf_00000098.bin.
This is the LibreDrive microcode, and so you really should have it :). And if you don't, it implies that MakeMKV doesn't have a network connection to MakeMKV's servers.
You can also download it manually from https://www.makemkv.com/svq/sdf.bin, copy it into your C:\Users\ianw/.MakeMKV directory, and MakeMKV will add it to _private_data.tar when you start it next.
IanW555
#6 Post by IanW555 » Sun Oct 26, 2025 7:18 pm
SamuriHL wrote: Sun Oct 26, 2025 5:36 pm Something is wrong with your drive then. Without LibreDrive being active, it's not going to work. As to why that's happening, if you've power cycled it, no idea. Whenever you see the Can't get VID... message, it means LibreDrive isn't working right.
Sorry, I'm confused, when I start MakeMKV it says LibreDrive is enabled?
IanW555
#7 Post by IanW555 » Sun Oct 26, 2025 7:20 pm
MrPenguin wrote: Sun Oct 26, 2025 6:32 pm
It does contain this file, amongst lots of other files in the folder.
