F1 4k movie
Mymovies223
F1 4k movie
Is anyone else having trouble ripping the F1 movie from this year? When I put the disk in, it spins around for about 5 minutes then says no disk. Any help?
MrPenguin
Re: F1 4k movie
Other people have managed to rip their F1 disks: viewtopic.php?f=12&t=39515Mymovies223 wrote: Sat Oct 25, 2025 8:51 pm Is anyone else having trouble ripping the F1 movie from this year? When I put the disk in, it spins around for about 5 minutes then says no disk. Any help?
Does MakeMKV's Info window say that your UHD drive has enabled LibreDrive?
Re: F1 4k movie
Clean the disc before trying again.Mymovies223 wrote: Sat Oct 25, 2025 8:51 pm Is anyone else having trouble ripping the F1 movie from this year? When I put the disk in, it spins around for about 5 minutes then says no disk. Any help?
DennisH
Re: F1 4k movie
I am also having an issue. I can get all the titles except the movie. There is plenty of space and I have ripped my other 4K discs. I get these errors ( and others like it). I included the errors and my info from makemkv. I ran the KeyDB_Helper and see that the disk is FOUND and VALID in the disc info.
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '56937019392'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '56937019392'
Failed to save title 1 to file D:/Video/F1_t01.mkv
0 titles saved, 1 failed
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: KLZK6JXXXXX - redacted
Highest AACS version: 82
Firmware version: 1.05
Disc Information
Label: F1
Timestamp: 2025-08-14 21:36:24
Protection: AACS2.0/C v82
Data capacity: 77.92 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Revision: 1.05
Disc Information
Label: F1
Number of layers: 3
Re: F1 4k movie
Try cleaning the disc. Even if brand new!DennisH wrote: Tue Nov 25, 2025 1:53 am I am also having an issue. I can get all the titles except the movie. There is plenty of space and I have ripped my other 4K discs. I get these errors ( and others like it). I included the errors and my info from makemkv. I ran the KeyDB_Helper and see that the disk is FOUND and VALID in the disc info.
Revision: 1.05
Disc Information
Label: F1
Number of layers: 3
DennisH
Re: F1 4k movie
Thought that might work but still have an error. Actually I have several, but truncated to just the unique ones. Turned on debug this time in case anyone knows what it means... I'll try cleaning again.
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00075.m2ts' at offset '73673342976'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '73673342976'
DEBUG: Code 3221225488 at _worNE:(,lg'T'0g]I:213131502
DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:29395793
DEBUG: Code 0 at h97u/P'k6LzLo#gYp;Jg:29394068
DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:213131157
DEBUG: Code 0 at %>PdCTzv+:fz/M&2tT6A:121262647
DEBUG: Code 35973312 at %>PdCTzv+:fz/M&2tT6A:121261773
DEBUG: Code 0 at wjQpM6}A<vw#Y6gW%jhaj:121268972
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 2 to file D:/Video/F1-FPL_MainFeature_t02.mkv
mossman1120
Re: F1 4k movie
I had a lot of trouble with mine as well even after cleaning it and moving it between drives.Mymovies223 wrote: Sat Oct 25, 2025 8:51 pm Is anyone else having trouble ripping the F1 movie from this year? When I put the disk in, it spins around for about 5 minutes then says no disk. Any help?
