Public KeyDB Disc Submissions
Harry707
Didi auf vollen Touren
https://www.mediafire.com/file/yc40u55z ... 0.tgz/file
Didi - Der Doppelgänger
https://www.mediafire.com/file/547re1za ... 2.tgz/file
Warbington
Toad King
jayteelan
Bjork - Cornucopia UHD dump
https://drive.google.com/file/d/17s4wLR ... sp=sharing
Fresca
I did last night before submitting this and it still did not work, so I'm thinking it's not supported yet.MrPenguin wrote: Tue Oct 21, 2025 10:59 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV? I believe your disk is already supported.Fresca wrote: Tue Oct 21, 2025 10:48 pm Dump for the new WAC Curse of Frankenstein 4K (MKB20_v82_The_Curse_of_Frankenstein_-_UHD_Disc_1_1318). https://mega.nz/file/pD5UmZIa#faPiWhKsV ... gDYjhR7ZJc
keydb_helper
Thanks to everyone who provided new UHD disc dumps. All posted UHD titles have been added to the public keydb. The following disc variants were new additions to the keydb:
MKB20_v76_KSU_40_LECIE_3F1C
MKB20_v77_Italian_Job_2003_A974
MKB20_v77_Samurai_fury_F970
MKB20_v77_The_Naked_Gun_9026
MKB20_v82_DIDI_-_AUF_VOLLEN_TOUREN_F850
MKB20_v82_DIDI_-_DER_DOPPELGÄNGER_6612
MKB20_v82_Eyes_Without_A_Face_954C
MKB20_v82_F1_AFD2
MKB20_v82_SHIN_GODZILLA_CF30
MKB_v82_KPAX_21EC
Your disc was added to the public keydb on October 17. If you still can't process it that means you haven't configured MakeMKV to use the public keydb.Fresca wrote: Thu Oct 23, 2025 1:09 am I did last night before submitting this and it still did not work, so I'm thinking it's not supported yet.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
corky7
MrPenguin
If your TGZ dump file is named "MKB20_v82_SHIN_GODZILLA_CF30.tgz" then it has already been added to KEYDB. However, if not then you would still need to change its "Share" setting so that people could access it.
corky7
Share changed. My bad. When I go to rip it shows it’s still encrypted. I restarted the container and updated the KEYDBMrPenguin wrote: Thu Oct 23, 2025 6:39 pmIf your TGZ dump file is named "MKB20_v82_SHIN_GODZILLA_CF30.tgz" then it has already been added to KEYDB. However, if not then you would still need to change its "Share" setting so that people could access it.
MrPenguin
No, it's still refusing to download.
corky7
MrPenguin
Thanks, the new links works.
Fresca
Realized the problem - KeyDBHelper was downloading a blank file so it was wiping out the existing keydb.cfg file. It's working now!keydb_helper wrote: Thu Oct 23, 2025 2:47 amYour disc was added to the public keydb on October 17. If you still can't process it that means you haven't configured MakeMKV to use the public keydb.Fresca wrote: Thu Oct 23, 2025 1:09 am I did last night before submitting this and it still did not work, so I'm thinking it's not supported yet.
OldCavalier
Posting for a new Reservoir Dogs variant I ran across. First time posting let me know if I messed up
Daredevil786
