Dump Submitted The Croods A New Age
TWBalls
Post by TWBalls » Mon May 19, 2025 5:20 am
MKB20_v76_The_Croods-_A_New_Age_5133.tgz submitted
MrPenguin
Re: Dump Submitted The Croods A New Age
Post by MrPenguin » Mon May 19, 2025 7:42 pm
TWBalls wrote: Mon May 19, 2025 5:20 am MKB20_v76_The_Croods-_A_New_Age_5133.tgz submitted
If that fails, could you also provide your TGZ dump file here please? Either as an attachment or via a download link? This would help The Powers That KEYDB support your disk too.
TWBalls
Post by TWBalls » Wed Oct 22, 2025 6:51 am
My apologies for the late reply, but I don't post here often. At the time, I had tried downloading the keydb.cfg file and it didn't work for me (It's definitely helped in the past multiple time though, so thanks!). I think I ended up trying a week later and it worked.
Anyway, I'm going off of older information, I was was just emailing it to the makemkv email address they mention in one of the stickies. Should I be uploading it to a cloud drive and posting a link instead?
MrPenguin
Post by MrPenguin » Wed Oct 22, 2025 5:30 pm
TWBalls wrote: Wed Oct 22, 2025 6:51 am Anyway, I'm going off of older information, I was was just emailing it to the makemkv email address they mention in one of the stickies. Should I be uploading it to a cloud drive and posting a link instead?
Always email to svq@makemkv.com, but replying with a public download link is also a Good Idea as it allows people to try adding your disk to the KEYDB.cfg file as well.
Do you still have that TGZ dump file please? It might be worth checking whether it is in the KEYDB file yet.
TWBalls
Post by TWBalls » Thu Oct 23, 2025 4:01 am
MrPenguin wrote: Wed Oct 22, 2025 5:30 pm Always email to svq@makemkv.com, but replying with a public download link is also a Good Idea as it allows people to try adding your disk to the KEYDB.cfg file as well.
Ah, okay. I'll do that in the future.
Here's the link for this one:
https://drive.google.com/file/d/1TdcBK- ... sp=sharing
MrPenguin
Post by MrPenguin » Thu Oct 23, 2025 10:21 am
TWBalls wrote: Thu Oct 23, 2025 4:01 am Ah, okay. I'll do that in the future.
Thanks, and can you also zip up the AACS/MKB_RO.inf file from your physical UHD disk please, and provide a download link for that too? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone except MakeMKV itself.
