MKB20_v77_DAS_CABINET_DES_DR_CALIGARI_-_4K_UHD_DD61 dump submitted via email as well
Sorry, Pioneer drive only.
Dump submitted - Das Cabinet des Dr. Caligari (1920)
NotaNumber
Re: Dump submitted - Das Cabinet des Dr. Caligari (1920)
Could you also zip up the AACS/MKB_RO.inf file from your physical UHD disk please, and provide it via a public download link? The MKB_RO.inf file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone other than MakeMKV itself.NotaNumber wrote: Wed Oct 22, 2025 9:51 pm MKB20_v77_DAS_CABINET_DES_DR_CALIGARI_-_4K_UHD_DD61 dump submitted via email as well
NotaNumber
It's not very large, here you go.
I only have a Pioneer drive, unfortunately. I tried XReveal and it says I need to upgrade to Pro for this disc
https://drive.google.com/file/d/1OiLsTb ... sp=sharing
NotaNumber
I check in February 2026 and XReveal had this in their database so I was able to rip the disk.
Thanks to all that helped.
