Dump submitted - Das Cabinet des Dr. Caligari (1920)
NotaNumber
Post by NotaNumber »
MKB20_v77_DAS_CABINET_DES_DR_CALIGARI_-_4K_UHD_DD61 dump submitted via email as well
Sorry, Pioneer drive only.
MrPenguin
Re: Dump submitted - Das Cabinet des Dr. Caligari (1920)
Post by MrPenguin »
NotaNumber wrote: Wed Oct 22, 2025 9:51 pm MKB20_v77_DAS_CABINET_DES_DR_CALIGARI_-_4K_UHD_DD61 dump submitted via email as well
Could you also zip up the AACS/MKB_RO.inf file from your physical UHD disk please, and provide it via a public download link? The MKB_RO.inf file inside your TGZ dump file has been truncated to only 56 bytes, which makes it unusable to anyone other than MakeMKV itself.
NotaNumber
It's not very large, here you go.
I only have a Pioneer drive, unfortunately. I tried XReveal and it says I need to upgrade to Pro for this disc :?
https://drive.google.com/file/d/1OiLsTb ... sp=sharing
NotaNumber
I check in February 2026 and XReveal had this in their database so I was able to rip the disk.
Thanks to all that helped.
