I did the same but I got weird error messages said that:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:9'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:9'
I use LG BP60NB10 drive. I had never seen that error messages before. I tried different disc (different movie) and it worked fine.
Any solutions?
Thanks,
Tim
Marvel - Fantastic Four - First Steps - protection key errors
Re: Marvel - Fantastic Four - First Steps - protection key errors
It looks like your drive hasn't enabled LibreDrive. What does MakeMKV's info window say?Sword7 wrote: Sat Oct 18, 2025 5:03 pm I did the same but I got weird error messages said that:
I tried that again but got same errors. I checked drive info. It said that LivreDrive is enabled. It does not make sense.
OS device name: /dev/sr0
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2120-05-07 09:35
Highest AACS version: 82
Firmware version: 1.02
Disc Information
Label: MARVEL_STUDIOS_FANTASTIC_FOUR
Timestamp: 2025-08-27 10:04:20
Protection: AACS2.0/C v77
Data capacity: 50.55 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Revision: 1.02
Serial number:
Disc Information
Number of layers: 2
All I can suggest is that you power-cycle your drive and try again. Perhaps wait until your OS has recognized the disk before launching MakeMKV, in case there's a race here somewhere.Sword7 wrote: Sat Oct 18, 2025 6:13 pm LibreDrive Information
Yes, it finally worked now. I just turned it off then turned back on.
I found out that my drive crashed during loading disc, and it automatically restarted but did not execute LibreDrive routines.
Thanks for your replies.
Tim
Tim
I just recieved mine in the mail today and bugger it, it's a very bad attempt at a bootleg!! Both the BD disc and the UHD disc are empty DVD-R 4.38GB discs with the label printed on them!!! Now in the process of arranging a return/refund with Amazon.
I'll have to re-order now.
