UHD FAQ
ShoutingMan
Re: UHD FAQ
Post by ShoutingMan » Sat Aug 23, 2025 7:12 pm
SamuriHL wrote:
Fri Jan 17, 2025 2:43 pm
KeyDB Helper (Windows Only)
https://www.mediafire.com/file_premium/ ... .6.7z/file
* Extract it to a folder
* Run it...it will download a copy of FindVUK and configure it
Ok, this is amazing. Have a brand new UHD disc for my wife's birthday and this enabled MakeMKV to rip it!
HSamwel
Re: UHD FAQ
Post by HSamwel » Sun Aug 24, 2025 7:04 pm
The following functions are available:
* Synchronize - Syncs the keydb.cfg file using FindVUK and then copies it to the MakeMKV data directory
* Validate - Validates your disc in the KeyDB file. This is a VERY good thing to be doing with all your discs!! It helps to maintain the integrity of the KeyDB.
* Disc Info - Shows you the information for your disc including the disc ID. If your KeyDB.cfg file contains device keys and/or processing keys, it COULD, in theory, maybe use those to ADD entries to the KeyDB. You know, for those pesky MKB v82 blu-rays everyone is loving.
* Disc Hash - Content Hash validation for the disc. I personally use this on my mounted protected ISOs after creating them to validate they're good but you can use it directly on a disc if you want, it'll just be slower
* Search - Allows you to search for a disc ID to see if it's in the keydb
* Fix... - Special option used for very specific reasons. Allows updating of the keydb in some situations.
The MKB v82 device key has been added to the public keydb.cfg. You no longer need to add it using the Fix functionality in my tool.
Once in a great while when the luck of the stars work in your favor, SOMETIMES on rare occasions this disc info process might help you find a VUK for a UHD that you're waiting for. To be clear, this code contains ZERO keys and there are NO public AACS 2.x processing keys...but sometimes you get lucky with other entries that could be in the KeyDB just waiting to be taken advantage of at times.
NOTE: This will not work on certain Pioneer drives. The VID needs to be able to be read correctly for it to work.
If you see [MakeMKV SUPPORTED]: FALSE it means that the KeyDB entry does not contain a VUK. You should post a dump or a link to a dump for your disc to see if someone can add a full entry to the KeyDB for your disc
That's all it does. But should make things easier for those who use the KeyDB in concert with MakeMKV.
NOTE: This will require .NET 8 Framework runtime be installed. You can find the latest here:
https://dotnet.microsoft.com/en-us/download/dotnet/8.0
Get the Windows X64 installer.
1.0.0.1 Added notification if title supported by MakeMKV
1.0.0.2 Fixed path not found exception when attempting to create an empty keydb.cfg file on startup
1.0.1.0 Enhanced Disc Info functionality; FindVUK Validate disc functionality added
1.0.1.1 Log inflation bug...accidentally left debug logging statement in causing log to grow exponentially...oops
1.0.1.2 Add unit key validation and keydb entry updating when local validation succeeds but differs from keydb
1.0.1.3 Forgot to compare the actual unit keys
1.0.1.4 Lots of internal bug fixing
1.0.1.5 Added new Fix... option for updating the keydb.cfg in certain circumstances
1.0.1.6 Add tooltips; Add Disc Hash; Faster VID parsing; Fixed bug in Fix function if header is missing
Hi!
A question..
Could you add an extra copy of the KeyDB file if it already exist in "C:\Programdata\aacs\"?
This is for VLC!
It too bad they all can't use the same path to KeyDB. VLCs path looks like a good general path for it actually.
Re: UHD FAQ
Post by SamuriHL » Sun Aug 24, 2025 7:29 pm
I don't have a lot of time at the moment but if I remember next time I'm in there I can add that.
HSamwel
Re: UHD FAQ
Post by HSamwel » Sat Oct 18, 2025 11:28 am
How about now? Anything changed with regarding to free time?
I would like to add to my previous request.
Could you add a configurable list of paths to do this copy to? I have seen other apps that put the kayDB.cfg file
at different paths.
MrPenguin
Re: UHD FAQ
Post by MrPenguin » Sat Oct 18, 2025 11:37 am
at different paths.
Don't VLC and FindVUK both use libaacs? In which case, I would expect them both to look for KEYDB.cfg in the same directory.
Re: UHD FAQ
Post by SamuriHL » Sat Oct 18, 2025 11:14 pm
No, I'm working on another project that has far higher priority right now. I don't know when I'll have time again to work on this.
at different paths.
No. I'm not overly complicating my code for other applications, sorry. I will add a check for the one location, but I'm certainly not creating a configurable list of paths.
thetoad
Re: UHD FAQ
Post by thetoad » Mon Oct 27, 2025 11:09 am
it be nice if you provided source code. :)
Re: UHD FAQ
Post by SamuriHL » Mon Oct 27, 2025 12:27 pm
No.
koberulz
Re: UHD FAQ
Post by koberulz » Sat Nov 01, 2025 2:29 am
Getting this error when using Disc Info in KeyDBHelper:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: Incorrect function. : 'E:\BDMV\STREAM\00006.m2ts'
at System.IO.RandomAccess.ReadAtOffset(SafeFileHandle handle, Span`1 buffer, Int64 fileOffset)
at System.IO.Strategies.OSFileStreamStrategy.Read(Span`1 buffer)
at System.IO.Strategies.OSFileStreamStrategy.Read(Byte[] buffer, Int32 offset, Int32 count)
at System.IO.Strategies.BufferedFileStreamStrategy.ReadSpan(Span`1 destination, ArraySegment`1 arraySegment)
at System.IO.Strategies.BufferedFileStreamStrategy.Read(Byte[] buffer, Int32 offset, Int32 count)
at KeyDBHelper.DiscUtils.ReadAlignedUnits(String filePath, Int32 unitCount)
at KeyDBHelper.DiscUtils.getDiscInfo(String disc, String aacsDir)
at KeyDBHelper.KeyDBHelper.btnDiscInfo_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 8.0.0.0
KeyDB_Helper
Assembly Version: 1.0.1.6
System.Runtime
System.Drawing.Primitives
Re: UHD FAQ
Post by SamuriHL » Sat Nov 01, 2025 4:24 pm
Clean your disc and try again. It's getting read errors.
oranje
Re: UHD FAQ
Post by oranje » Tue Nov 04, 2025 3:37 pm
This is an excellent resource!
sandersoni
Re: UHD FAQ
Post by sandersoni » Sat Nov 22, 2025 5:11 pm
Can i point this at a backed-up disc on my hard disk?
Re: UHD FAQ
Post by SamuriHL » Sat Nov 22, 2025 7:42 pm
It works with mounted ISO images and discs only.
rjstauber
Re: UHD FAQ
Post by rjstauber » Tue Dec 23, 2025 8:50 pm
This Key DB Helper is a great tool.
When I click on "Synchronize", the program stops and I get a message from McAffee that I was just protected...
Do I need to turn McAffee off?
So far, I had no luck trying to rip the Japanese Blu-ray of Pink Floyd's WYWH 50, seems like the key is still missing.
Re: UHD FAQ
Post by d00zah » Tue Dec 23, 2025 11:25 pm
Most AV products allow the user to make an exception for a specific app. If that makes you uncomfortable, submit a FP (false positive) report to McAffee & they will address it in the next definition update.
KeyDB_Helper.dll
FindVUK - Synchronize.bat
The 1st 2 seem to be "clean", but some (incl. McAffee) scanners take issue w/:
FindVUK.exe
