blu-ray Nobody 2
kahasm
blu-ray Nobody 2
Post by kahasm »
the following is what info I get when attempting to open disc:
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?o+IZXkFpXFGixm...
Saved AACS dump file as C:\Users\storm/.MakeMKV/MKB_v82_Nobody_2_CF48.tgz
using latest version 1.18.2, java 1.8.0_461 (latest)
Re: blu-ray Nobody 2
kahasm wrote:
Thu Oct 09, 2025 3:28 am
The standard process is the first point below:
  • Email the generated tgz dump file to svq@makemkv.com so that MakeMKV can derive the key and add it to their internal hashed keys.
  • So now that you have emailed the dump, if you also would like to help the community, first download the latest public KeyDB zip file and extract it to the MakeMKV data directory (where the dumps are locted). After doing this, if you still cannot rip the disc, make a post providing:
    • the drive model used to create the dump file.
    • the full name of the dump file.
    • a download link for the dump file after you have hosted it somewhere.
Qwonset The Hutt
Post by Qwonset The Hutt »
Same thing here.
The dump file is at:
The https://drive.proton.me/urls/Z4RGC3CEBM#BltHp3gLB9Ag.
Jabba, you ff, stop stalking me or I'll tell mom.
MrPenguin
Post by MrPenguin »
Qwonset The Hutt wrote:
Thu Oct 09, 2025 11:17 am
Same thing here.
Qwonset The Hutt
MrPenguin wrote:
Thu Oct 09, 2025 2:07 pm
Same thing here.
Ha! I assumed it wasn't there yet. Thx!
BobAnalouge
Post by BobAnalouge »
The latest KeyDB file was able to decrypt the US/Canada release of Nobody 2.
sniep
Post by sniep »
Does anyone have a download link handy to the KEYDB? I've not done this method yet but I am also getting this error for this title, a link would be appreciated!
Edit: To be clear the one above 503 errors out. I dont know if you need to request these links each time? If so can I have one made please?
Edit 2: It's now working. Thanks.
chriska416
Post by chriska416 »
The latest version of MakeMKV v1.18.2 fixes the issues with this disk.
