MKB20_v77_The_wandering_earth_E3F3.tgz
BaiDuYunPan
Post by BaiDuYunPan » Sat Oct 11, 2025 8:18 am
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Backing up disc into folder "E:/Video/backup/The wandering earth"
Saved AACS dump file as C:\Users\BaiDuYunPan/.MakeMKV/MKB20_v77_The_wandering_earth_E3F3.tgz
Backup failed
Dump submitted, thank you!
MrPenguin
Re: MKB20_v77_The_wandering_earth_E3F3.tgz
Post by MrPenguin » Sat Oct 11, 2025 12:19 pm
Could you also upload this file (along with the AACS/MKB_RO.inf file from your physical UHD disk) into (say) OneDrive or Google Drive please, and then reply with public download links? This would allow people to try adding your disk to the public KEYDB.cfg file too.
We would need the AACS/MKB_RO.inf file from your disk because the copy of this file inside your TGZ dump has almost certainly been truncated to only 56 bytes, making it unusable to anyone except MakeMKV itself.
BaiDuYunPan
Post by BaiDuYunPan » Mon Oct 13, 2025 9:50 am
https://drive.google.com/file/d/1ZYPxEy ... sp=sharing
我直接复制了,光盘里的AACS到我的硬盘里,我不知道这样是否可行,谢谢。
如果我的操作操作有问题的话请指出,谢谢。
MrPenguin
Post by MrPenguin » Mon Oct 13, 2025 10:18 am
您能提供一下 MakeMKV 產生的 discatt.dat 檔案嗎?裡麵包含我們需要與 AACS 目錄合併的元資料。謝謝。
或者,只需要 MKB20_v77_The_wandering_earth_E3F3.tgz 檔案?
Nín néng tígōng yīxià MakeMKV chǎnshēng de discatt.Dat dǎng'àn ma? Lǐmiàn bāohán wǒmen xūyào yǔ AACS mùlù hébìng de yuán zīliào. Xièxiè.
Huòzhě, zhǐ xūyào MKB20_v77_The_wandering_earth_E3F3.Tgz dǎng'àn?
BaiDuYunPan
Post by BaiDuYunPan » Mon Oct 13, 2025 11:54 am
MrPenguin
Post by MrPenguin » Mon Oct 13, 2025 12:14 pm
非常感谢。
謝謝,但我注意到您使用 Pioneer UHD 硬碟建立了這個 TGZ 轉儲檔案。請問您能使用 LG/ASUS/Buffalo UHD 硬碟重新建立這個轉儲檔案嗎?
Xièxiè, dàn wǒ zhùyì dào nín shǐyòng Pioneer UHD yìng dié jiànlìle zhège TGZ zhuǎn chǔ dǎng'àn. Qǐngwèn nín néng shǐyòng LG/ASUS/Buffalo UHD yìng dié chóngxīn jiànlì zhège zhuǎn chǔ dǎng'àn ma?
BaiDuYunPan wrote:
Wed Nov 13, 2024 11:46 pm
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
BaiDuYunPan
Post by BaiDuYunPan » Tue Oct 14, 2025 3:18 am
好的,https://drive.google.com/file/d/1bLzucO ... sp=sharing
这个是使用BW-16D1HT拷贝The_wandering_earth时创建的转储文件,就在刚刚
MrPenguin
Post by MrPenguin » Tue Oct 14, 2025 10:58 am
啊哈!
003346:0000 需要 LibreDrive 兼容驱动器来打开此光盘 - 视频无法解密。
為了解密您的磁碟,我們需要一個與 LibreDrive 相容的 UHD 磁碟機。
請問 MakeMKV 的資訊視窗是否顯示可以支援 LibreDrive?如果顯示,您需要先更新其韌體。
log.txt 檔案需要包含如下一行:
001011:0000 正在使用 LibreDrive 模式 (v06.3 id=0FA242DD4D0B)
Wèi liǎo jiěmì nín de cí dié, wǒmen xūyào yīgè yǔ LibreDrive xiāng róng de UHD cí dié jī.
Qǐngwèn MakeMKV de zīxùn shìchuāng shìfǒu xiǎnshì kěyǐ zhīyuán LibreDrive? Rúguǒ xiǎnshì, nín xūyào xiān gēngxīn qí rèn tǐ.
Log.Txt dǎng'àn xūyào bāohán rúxià yīxíng:
BaiDuYunPan
Post by BaiDuYunPan » Tue Oct 14, 2025 11:54 am
驱动器信息
操作系统设备名: I:
当前配置文件: BD-ROM
制造商: ASUS
产品: BW-16D1HT
修订版本: 3.10
序列号: KLJO15B3206
固件日期: 2119-01-04 10:14
总线加密标识符: 1F
最高 AACS 版本: 81
LibreDrive 信息
状态: 已启用
驱动器平台: MT1959
固件类型: 已应用补丁(重新启用微代码访问)
固件版本: 3.10
DVD 全区域: 是
BD 原始数据读取: 是
BD 原始元数据读取: 是
无限制读取速度: 是
光盘信息
标签: The wandering earth
时间戳: 2024-04-24 09:47:24
保护措施: AACS2.0/C v77
数据容量: 87.43 Gb
光盘类型: BD-ROM UHD
层数: 3
总线加密标识符: 80
MakeMKV v1.18.1 win(x64-release) 已启动
正在备份光盘至文件夹 "E:/视频/backup/The wandering earth"
已保存 AACS 转储文件至 C:\Users\BaiDuYunPan/.MakeMKV/MKB20_v77_The_wandering_earth_E3F3.tgz
备份失败
他没有显示我不知道在哪里可以看到
MrPenguin
Post by MrPenguin » Tue Oct 14, 2025 12:04 pm
LibreDrive 信息
状态: 已启用
驱动器平台: MT1959
固件版本: 3.10
DVD 全区域: 是
BD 原始数据读取: 是
BD 原始元数据读取: 是
无限制读取速度: 是
备份失败
他没有显示我不知道在哪里可以看到
你的 UHD 驅動器似乎支援 LibreDrive,但 MakeMKV 可能還沒下載 LibreDrive 微碼?因為 LibreDrive 顯然尚未啟用。
您可以在 _private_data.tar 檔案中看到一個名為 sdf_00000098.bin 的檔案嗎?
$ tar tvf ~/.MakeMKV/_private_data.tar | grep sdf
-rw-r--r-- 0/0         1408816 1970-01-01 01:00 sdf_00000098.bin
Nín kěyǐ zài _private_data.Tar dǎng'àn zhòng kàn dào yīgè míng wèi sdf_00000098.Bin de dǎng'àn ma?
Nǐ de UHD qūdòngqì sìhū zhīyuán LibreDrive, dàn MakeMKV kěnéng hái méi xiàzài LibreDrive wēi mǎ? Yīnwèi LibreDrive xiǎnrán shàngwèi qǐyòng.
MrPenguin
Post by MrPenguin » Tue Oct 14, 2025 1:11 pm
驱动器信息
操作系统设备名: I:
当前配置文件: BD-ROM
制造商: ASUS
产品: BW-16D1HT
修订版本: 3.10
序列号: KLJO15B3206
总线加密标识符: 1F
最高 AACS 版本: 81
我問過一位專家,他們說:
是的,應該可以刷入。我相信他可以直接升級到 3.10MK 韌體。 3.10MK 可能是我看到的 BW-16D1HT 最受歡迎的版本。
Shì de, yīnggāi kěyǐ shuā rù. Wǒ xiāngxìn tā kěyǐ zhíjiē shēngjí dào 3.10MK rèn tǐ. 3.10MK kěnéng shì wǒ kàn dào de BW-16D1HT zuì shòu huānyíng de bǎnběn.
BaiDuYunPan
Post by BaiDuYunPan » Tue Oct 14, 2025 1:45 pm
LibreDrive 信息
状态: 已启用
驱动器平台: MT1959
固件版本: 3.10
DVD 全区域: 是
BD 原始数据读取: 是
BD 原始元数据读取: 是
无限制读取速度: 是
备份失败
他没有显示我不知道在哪里可以看到
可以看到BIN文件,https://drive.google.com/file/d/1EOtDDp ... sp=sharing
BaiDuYunPan
Post by BaiDuYunPan » Tue Oct 14, 2025 1:48 pm
驱动器信息
操作系统设备名: I:
当前配置文件: BD-ROM
制造商: ASUS
产品: BW-16D1HT
修订版本: 3.10
序列号: KLJO15B3206
总线加密标识符: 1F
最高 AACS 版本: 81
我問過一位專家,他們說:
目前就是3.10固件,其他UHD都可以翻录,但目前就是The_wandering_earth无法翻录
MrPenguin
Post by MrPenguin » Tue Oct 14, 2025 1:54 pm
可以看到BIN文件
不對。 MakeMKV 應該已經下載了很多檔案到 _private_data.tar 中了。
Bùduì. MakeMKV yīnggāi yǐjīng xiàzàile hěnduō dǎng'àn dào _private_data.Tar zhōngle.
一個建議
這仍然是一個小秘密,但擁有這個文件對你來說還是有好處的。你可以隨時從 https://www.makemkv.com/svq/sdf.bin 手動下載 SDF.bin,並將其放入 MakeMKV 資料目錄中。下次啟動時,MakeMKV 將讀取該檔案並停止運作。
Zhè réngrán shì yīgè xiǎo mìmì, dàn yǒngyǒu zhège wénjiàn duì nǐ lái shuō háishì yǒu hǎo chǔ de. Nǐ kěyǐ suíshí cóng https://Www.Makemkv.Com/svq/sdf.Bin shǒudòng xiàzài SDF.Bin, bìng jiāng qí fàng rù MakeMKV zīliào mùlù zhōng. Xià cì qǐdòng shí,MakeMKV jiāng dòu qǔ gāi dǎng'àn bìng tíngzhǐ yùnzuò.
您的資料目錄是 C:\Users\BaiDuYunPan/.MakeMKV
Nín de zīliào mùlù shì C:\Users\BaiDuYunPan/.MakeMKV
MrPenguin
Post by MrPenguin » Tue Oct 14, 2025 3:23 pm
MakeMKV 顯然已經成功停用了你的 UHD 磁碟機的匯流排加密,這足以在 MakeMKV 已知磁碟金鑰的情況下翻錄磁碟。問題在於,你的 TGZ 轉儲檔案包含的資訊不足以讓人發現未知密鑰。
您的 _private_data.tar 檔案也不包含 MakeMKV 的「雜湊金鑰」資料庫,因此我必須假設 MakeMKV 正在使用 KEYDB.cfg 中的金鑰來解密您的其他藍光光碟。
MakeMKV xiǎnrán yǐjīng chénggōng tíng yòngle nǐ de UHD cí dié jī de huìliú pái jiāmì, zhè zúyǐ zài MakeMKV yǐ zhī cí dié jīn yào de qíngkuàng xià fānlù cí dié. Wèntí zàiyú, nǐ de TGZ zhuǎn chǔ dǎng'àn bāohán de zīxùn bú zú yǐ ràng rén fāxiàn wèizhī mì yào.
Nín de _private_data.Tar dǎng'àn yě bù bāohán MakeMKV de `zácòu jīn yào'zīliào kù, yīncǐ wǒ bìxū jiǎshè MakeMKV zhèngzài shǐyòng KEYDB.Cfg zhōng de jīn yào lái jiěmì nín de qítā lánguāng guāngdié.
