Public KeyDB Disc Submissions
mali40
I have to say a big thank you now, it went really fast now. And I could read the disc because it was in the key dB.cfg. Thank you very much.
Will this remain a component of the key db?
Yes. The database is only increasing and no titles will be deleted.
mali40
Betreff: Public KeyDB-Disc-Einreichungen
But if titles are not yet in the dB, you have to report them here in the forum first?Coopervid wrote: Sun Oct 12, 2025 3:47 pm Yes. The database is only increasing and no titles will be deleted.
Re: Betreff: Public KeyDB-Disc-Einreichungen
The first post of this thread explains that in great detail what to do. Always do a synchronize step before doing so as it is annoying to have complaints that a title is not supported when people just have an old version of the database.
99gagamel
Könnt Ihr ein Laufwerk empfehlen was keine Hash Back Fehler verursacht und UHDs ausließt und sich Flashen lässt
A record for the Aussie UHD disc of MI Final Reckoning has now been added to the KeyDB.
Disc ID: 3D730A13D46C160A62F543A7A1464E8FEEC6DFCB
Disc version: MKB20_v82_MI_FINAL_RECKONING_625C
AnBird
Here's the dump and MKB RO for Lord of War 985D
https://mega.nz/folder/RAgg3Zgb#mJ3w62sCAegBvRbyD4JAyA
My apologies if this disc is already present, it's been a few days since I updated my DB, attempted the rip, and made the dump
Jimface
Hi everyone
Here's the dump for the UK 4K of TRON - https://www.dropbox.com/scl/fi/ytjblaig ... baeb8&dl=0
Many thanks
Many thanks
LaunderedShirt
North by Northwest from Alfred Hitchcock The Ultimate Collection
https://www.dropbox.com/scl/fi/2qtj0nd3 ... si45x&dl=0
LaunderedShirt
3 more from the Alfred Hitchcock Ultimate Collection
Rope
https://www.dropbox.com/scl/fi/ts78hsu4 ... lg5lx&dl=0
Topaz
https://www.dropbox.com/scl/fi/k1jm4q9v ... bjua7&dl=0
Torn Curtain
https://www.dropbox.com/scl/fi/2xuv32yh ... b4y99&dl=0
Rope
Topaz
Torn Curtain
AnBird
Dumps for a LOTR box set:
Fellowship of the Ring theatrical 40D5: https://mega.nz/folder/5BJGHYTT#N3VzwoC_4brGV0s_9JdVmA
Fellowship of the Ring extended pt 1 4247: https://mega.nz/folder/EFwgjYgB#WbXIlNKhktOj8XQTKRLBJQ
Fellowship of the Ring extended pt 2 23AD: https://mega.nz/folder/9QQyxRyQ#q_EeiMIF4LRXPAZpGnMGoQ
Two Towers theatrical CD9B: https://mega.nz/folder/dBRVGLaA#aeTbhAisIKybYur3tu7atA
Two Towers extended pt 1 3C99: https://mega.nz/folder/9NxAmBCC#HEhmiyOiycNvB0yZpLDLRg
Two Towers extended pt 2 E323: https://mega.nz/folder/AIpHzApI#irLuobBAGFx4HuJMvtFZdQ
Return of the King theatrical 5B15: https://mega.nz/folder/oFJAXApQ#Ut8UCXJxjhYCWB0UNe9dKQ
Return of the King extended pt 1 A361: https://mega.nz/folder/YIwi1LQJ#cU0Zrq3Wl6qFL95yPmDmDw
Return of the King extended pt 2 4707: https://mega.nz/folder/sA4V1LCA#754ZWdrKbIqzbDBL_dtk5Q
Thanks in advance!
Thanks in advance!
keydb_helper
Thanks to everyone who has provided a UHD disc dump. The following disc variants have been added to the public keydb:
MKB20_v68_Lord_of_War_985D
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_40D5
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_1_4247
MKB20_v76_The_Lord_of_the_Rings-_The_Fellowship_of_the_Ring_(EXT_)_PT_2_23AD
MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_5B15
MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_(EXT_)_PT_1_A361
MKB20_v76_The_Lord_of_the_Rings-_The_Return_of_the_King_(EXT_)_PT_2_4707
MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_CD9B
MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_1_3C99
MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_2_E323
MKB20_v77_North_by_Northwest_9A37
MKB20_v77_Rope_38F1
MKB20_v77_Topaz_FA77
MKB20_v77_Torn_Curtain_B7B1
MKB20_v77_Tron_939A
MKB20_v82_LaCasaSperdutaNelParco_DFDC
MKB20_v82_L_UltimoSaporeDellAria_645A
MKB20_v82_Ondata_di_piacere_2770
MKB20_v82_UominiSiNascePoliziottiSiMuore_UHD66_5438
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
GOTO GOSUB
Mission: Impossible - The Final Reckoning 4K UHD [Region A & B & C]
https://mega.nz/file/2iYmlA6K#LnYnTzm4D ... QOat6G2dk8
Thank you to everyone involved.
Update: I have updated my keydb.cfg database and resolved the issue. I will leave this here for reference although I suspect that no further action is required.
MrPenguin
This looks like the A432 variant, which should already be supported.GOTO GOSUB wrote: Tue Oct 14, 2025 7:51 am Mission: Impossible - The Final Reckoning 4K UHD [Region A & B & C]
GOTO GOSUB
MrPenguin wrote: Tue Oct 14, 2025 8:16 amThis looks like the A432 variant, which should already be supported.GOTO GOSUB wrote: Tue Oct 14, 2025 7:51 am Mission: Impossible - The Final Reckoning 4K UHD [Region A & B & C]
That was fast, you just beat me to it. Thank you for checking - apologies for the inconvenience.
