AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
mickhyperion
The new Hanna-Barbera Touché Turtle and Dum Dum discs are encoded with AACS v82 and MakeMKV says: "The volume key is unknown for this disc - video can't be decrypted."
I have sent the dump files for both discs to svq@makemkv.com and have posted them to Google Drive:
https://drive.google.com/file/d/1e382Yn ... share_link
https://drive.google.com/file/d/1ScclJN ... share_link
Thanks for your help!
MrPenguin
Re: AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
Can you adjust the "Share" option on both those files please, so that people can access them?mickhyperion wrote: Sun Oct 05, 2025 8:40 am The new Hanna-Barbera Touché Turtle and Dum Dum discs are encoded with AACS v82 and MakeMKV says: "The volume key is unknown for this disc - video can't be decrypted."
mickhyperion
Thanks! Those have been made shareable for all now.
MrPenguin
"Touché away!!!!!"
fschief
Here because I had the same issue. Watching in the hopes of finding a solution.
mickhyperion
Thanks MrPenguin and anyone else who helped. The latest keydb.cfg file did the trick!
Corey B
Is there a working as of yet? Still getting a failure to read disc.
Thanks for any help, and yes I too have sent submission.
MrPenguin
AFAIK the latest KEYDB.cfg file contains the keys for:Corey B wrote: Sun Oct 12, 2025 1:27 pm Is there a working as of yet? Still getting a failure to read disc.
- MKB_v82_TOUCHE_TURTLE_AND_DUM_DUM_D1_88A4.tgz
- MKB_v82_TOUCHE_TURTLE_AND_DUM_DUM_D2_3428.tgz
If your variant codes are different then could you upload your dumps into (say) OneDrive or Google Drive please, and then reply with public download links?
Corey B
Tried these discs with the latest KEYDB.cfg file and it still fails
https://drive.google.com/file/d/1vOtsoh ... drive_link
https://drive.google.com/file/d/1sso_HW ... drive_link
Please thank you for any help
Corey B
Sorry have done all of that and still fails.MrPenguin wrote: Sun Oct 12, 2025 2:56 pmAFAIK the latest KEYDB.cfg file contains the keys for:Corey B wrote: Sun Oct 12, 2025 1:27 pm Is there a working as of yet? Still getting a failure to read disc.If your dumps have the same variant codes (i.e. 88A4 and 3428) then downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV should work.
Corey B
Only way for this to work is to uncheck Decrypt which I've never had to do before. Hopefully it still works.
Corey B
Yes I have the same codes. Apparently they are no longer working unfortunately. And ripping undecrypted results in non playable discs. So no solution currently.
MrPenguin
Can you change the "Share" option for those files please, so that people can access them?Corey B wrote: Sun Oct 12, 2025 4:12 pm MKB_v82_TOUCHE_TURTLE_AND_DUM_DUM_D1_88A4
Corey B
All apologies access granted to all
MrPenguin
You have the exact same disks as the original poster, and the keys are indeed in the latest KEYDB.cfg file. See:Corey B wrote: Sun Oct 12, 2025 5:04 pm Yes I have the same codes. Apparently they are no longer working unfortunately. And ripping undecrypted results in non playable discs. So no solution currently.
0xC689B8479B0EFFD09643A2D9992FEB7C6294754F = TOUCHE TURTLE AND DUM DUM D1 (TOUCHE TURTLE AND DUM DUM D1) | D | 2025-08-28 | ...Code: Select all
0x6A2A96BFDD9B1D4DB7B8B213FE23E80F5ACF7CBA = TOUCHE TURTLE AND DUM DUM D2 (TOUCHE TURTLE AND DUM DUM D2) | D | 2025-08-27 | ...
