Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
MKVDUDE wrote:
Sun Oct 12, 2025 10:42 am
Your instincts were correct!
I went to the backup - the m2ts files play fine with VLC!
I deleted the AACS folder and now the backup runs fine through MakeMKV!
Thanks for your help!
Great to hear that worked out. I'll add it to the list of weirdly unencrypted UHD titles...
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
mali40
Post by mali40 »
MrPenguin wrote:
Sun Oct 12, 2025 10:51 am
mali40 wrote:
Sun Oct 12, 2025 7:16 am
I have three dump files here that I can't decrypt.
I'll give you an update.
So, I was able to read two discs.
But I can't decrypt 28 Years Later.
It doesn't seem to be included in the Key db .cfg.
MrPenguin
Post by MrPenguin »
mali40 wrote:
Sun Oct 12, 2025 12:26 pm
It's this entry:
0xE77E4797D5E234B5AAE62C1E7E170CBF33D0EA0E = 28_YEARS_LATER (28 Years Later - Blu-ray™) | D | 2025-07-25 | ...etc
I'm getting this today when I try to synchronize. Also posted in doom9 forum:
ERROR! #HTTPA_ERR_HEADERNOTFOUND
wester
Post by wester »
I can't seem to rip Zombieland, this one: https://www.blu-ray.com/movies/Zombiela ... ay/290022/
I've submitted it two times this year to the MakeMKV team.
Here's the AACS dump:
https://we.tl/t-tCFaInYAbi
Who can help?
mali40
Post by mali40 »
MrPenguin wrote:
Sun Oct 12, 2025 1:00 pm
It's this entry:
Are you telling me that it's in the .cfg file?
If so, I don't know why I can't decrypt it.
and i have the log copy:
Direct access mode is in use
Loading content hash table, verifying integrity of M2TS files.
This disc uses a newer version of AACS protection. Please inform us at http://www.makemkv.com/a/?FHbNX9jfQi3ST9...
AACS output file saved as C:/Sicherung/MKB_v82_28_Years_Later_E8D2.tgz
The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted
Opening the disc failed
MrPenguin
Post by MrPenguin »
mali40 wrote:
Sun Oct 12, 2025 1:12 pm
Yes, and it's also been validated and so we know it is correct.
mali40
Post by mali40 »
It's this entry:
MrPenguin wrote:
Sun Oct 12, 2025 1:18 pm
I believe you.
But as you can see, it can't be deciphered.
There must be a reason why it can't?
Most likely you are using non-standard directories for Makemkv. Read the first post of this thread and how to add keydb.cfg so makemkv can use it.
mali40
Post by mali40 »
Coopervid wrote:
Sun Oct 12, 2025 1:27 pm
Hi Coopervid,
Thanks for your post. I've already done it and I've been able to decrypt two discs, so I assume it was correct.
It's only failing because it's 28 years later.
mali40 wrote:
Sun Oct 12, 2025 1:39 pm
Hi Coopervid,
Have you updated the keydb.cfg recently? Using the synchronize.bat or KeydB_helper.exe if you are on Windows. If you use synchronize.bat you NEED also to copy the updated version to the .Makemkv directory. KeyDB_Helper does this automatically. However, like posted, I have issues today to connect.
Edit: The issue is gone and synchronize just worked.
mali40
Post by mali40 »
Coopervid wrote:
Sun Oct 12, 2025 1:46 pm
Hi Coopervid,
I just downloaded keydb helper and the disc info says the following:
Getting disc info...
Validation Data: F465AABBAE249B78171FD2DFD7AB4CF0 [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0xE77E4797D5E234B5AAE62C1E7E170CBF33D0EA0E
[Volume]: 28_YEARS_LATER
[Title]: 28 Years Later - Blu-ray™
[Date]: 2025-07-31
[VID]: 0x5D822FE017691B088653A9A1A980E60B
[MKB]: 82
[EncKey]: 1-0x32944D6F441ACB0B0EEE284919F9D3C4
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: BD
Use "synchronize" in KeyDB_Helper to get all new keys. Then try again. The disc IS in Keydb.cfg.
mali40
Post by mali40 »
Coopervid wrote:
Sun Oct 12, 2025 2:09 pm
Can you tell me which of these data is decisive?
mali40 wrote:
Sun Oct 12, 2025 2:13 pm
If you have a non-updated version of keydb.cfg using "synchronize" will add new keys. Afterwards use "disc info" and then it will tell you that the disc is now in your (updated) keydb.cfg while it may be missing now. The program checks only the downloaded version and not the version on the FindVUK server.
