Public KeyDB Disc Submissions
MrPenguin
Post by MrPenguin » Sat Oct 11, 2025 6:14 pm
mali40 wrote: Sat Oct 11, 2025 6:13 pm Hello, I would also like to post 3 dump files but unfortunately I don't have any cloud storage where I can upload them :(
OneDrive and Google Drive are both free to use.
zaqqaz6917
Post by zaqqaz6917 » Sat Oct 11, 2025 7:00 pm
MrPenguin wrote: Sat Oct 11, 2025 6:14 pm
Mediafire is good also, no ads
jacobmendez
Post by jacobmendez » Sat Oct 11, 2025 7:07 pm
Lights Out 4K UHD US MOD release dump linked here:
https://drive.google.com/file/d/1xrvl0B ... sp=sharing
Grahamdoh
Post by Grahamdoh » Sat Oct 11, 2025 7:08 pm
https://drive.google.com/drive/folders/ ... Q4FV9K_C0p
Martyrs
The Diabolical Dr Z
Both from Eureka
fox87
Post by fox87 » Sat Oct 11, 2025 7:26 pm
thank you. I just realized my keydb file was empty. now it's working :)
keydb_helper
Post by keydb_helper » Sun Oct 12, 2025 2:30 am
tylwyth wrote: Sat Oct 11, 2025 12:34 pm MKB20_v82_TWIN_PEAKS-_FIRE_WALK_WITH_ME_FE26
Dump for alternative variant of Criterion UK Twin Peaks FWWM
Hey tylwyth, thanks for the new disc dump. The FE26 variant of Twin Peaks: Fire Walk with Me has been added to the public keydb.
jacobmendez wrote: Sat Oct 11, 2025 7:07 pm Lights Out 4K UHD US MOD release dump linked here:
Hey Jacob, this is the third time you have posted in this thread and the third time your disc was already supported by the public keydb. I appreciate the intent to help but you aren't going about things the right way. From now on I'm going to ignore your posts unless you make it clear you have downloaded and tried the latest keydb immediately before posting.
MKVDUDE
Post by MKVDUDE » Sun Oct 12, 2025 2:37 am
keydb_helper wrote: Sat Oct 11, 2025 4:04 am Thanks to everyone who provided new UHD disc dump files. The following disc variants have been added to the public keydb:
MKB20_v82_City_On_Fire_0F34
MKB20_v82_MI_FINAL_RECKONING_619E
MKB20_v82_Red_Planet_9178
Hi Keydb_helper - I have managed to rip Red Planet, But City on Fire doesn't seem to be in the database yet as it won't rip despite having downloaded and tested the last 3 updates?
Any help would be greatly appreciated - Many thanks!
keydb_helper
Post by keydb_helper » Sun Oct 12, 2025 2:50 am
MKVDUDE wrote: Sun Oct 12, 2025 2:37 am Hi Keydb_helper - I have managed to rip Red Planet, But City on Fire doesn't seem to be in the database yet as it won't rip despite having downloaded and tested the last 3 updates?
Hey MKVDUDE, what is the exact error message shown when you try to process City On Fire?
I just double checked and I believe it is in the keydb. Open up the keydb.cfg file with a text editor and search for 0x62AC07902956D4888A7CE934917E967B47526B30. You should see a line like this (keys redacted for the forum):
0x62AC07902956D4888A7CE934917E967B47526B30 = City On Fire | D | 0000-00-00 | M | 0x86C6... | I | 0xE8E7... | V | 0x6A6F... | U | 1-0xB63E... ; MKBv82/BEE (UHD)
I did notice that unit key validation wasn't possible for your City On Fire disc as the kv.dat file contained no aligned units. Could you try unplugging your BU40N, restarting your computer, creating a new disc dump file and resubmitting it to this thread? If the volume ID was incorrect in your original disc dump that would prevent MakeMKV from processing your disc.
trobbins23
Post by trobbins23 » Sun Oct 12, 2025 3:00 am
Submitted "MKB20_v82_Superman_446E.tgz"
https://drive.google.com/open?id=129XJc ... p=drive_fs
MKVDUDE
Post by MKVDUDE » Sun Oct 12, 2025 3:10 am
keydb_helper wrote: Sun Oct 12, 2025 2:50 am
Unplugged and restarted as instructed.
I have tried to rip the disc itself, and the encrypted backup I have made.
Using the disc it takes an age going through the different m2ts files (Approx 15 mins) then acts as if its a fresh disc with this message -
MakeMKV v1.18.2 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.03 MO9L5U82152d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as /Users/n/Desktop/MKB20_v82_City_On_Fire_0F34.tgz
Attempting to rip from the encrypted backup flies through the process and gives the same result.
Fresh Dump from Disc - https://we.tl/t-9jKluh9WnS
Dump from Encrypted Backup - https://we.tl/t-krRAzLdUWI
Thanks for your help!
keydb_helper
Post by keydb_helper » Sun Oct 12, 2025 5:47 am
MKVDUDE wrote: Sun Oct 12, 2025 3:10 am Unplugged and restarted as instructed.
Fresh Dump from Disc - ...
Dump from Encrypted Backup - ...
Thanks for following up. I'm now wondering whether this may be another unencrypted disc...
You mentioned that you had created a protected backup. Could you please navigate to the BDMV/STREAM folder and try to play any of the M2TS files with a player such as VLC? Don't try to play the disc or backup as a Blu-ray with VLC, just open the M2TS file directly.
If you can play the files directly than your disc is like The Wicker Man and it isn't actually encrypted but the presence of the AACS folder confuses MakeMKV.
If you can't play any of the M2TS files with VLC I'd have to ask you to upload the smallest M2TS file from your decrypted backup to a file host and post the link here or send it via PM. If you could also zip up and provide the complete AACS folder that would be appreciated.
mali40
Post by mali40 » Sun Oct 12, 2025 7:16 am
Hello and good morning,
I have three dump files here that I can't decrypt.
the dump files are BD files.
https://www.mediafire.com/file/elgt0gv5 ... 2.tgz/file
https://www.mediafire.com/file/2reqpszs ... C.tgz/file
https://www.mediafire.com/file/hkbnpsm1 ... C.tgz/file
The drive is a LG BU 40.
i hope that is right and completely.
nblh0702
Post by nblh0702 » Sun Oct 12, 2025 9:15 am
Hello, i need help for this dump (bluray)
Thank you
https://drive.google.com/file/d/17ZGqA8 ... sp=sharing
MKVDUDE
Post by MKVDUDE » Sun Oct 12, 2025 10:42 am
keydb_helper wrote: Sun Oct 12, 2025 5:47 am
Your instincts were correct!
I went to the backup - the m2ts files play fine with VLC!
I deleted the AACS folder and now the backup runs fine through MakeMKV!
MrPenguin
Post by MrPenguin » Sun Oct 12, 2025 10:51 am
mali40 wrote: Sun Oct 12, 2025 7:16 am I have three dump files here that I can't decrypt.
