MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_BD66
ZoomBoy81
Post by ZoomBoy81 »
MrPenguin
Re: MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_BD66
Post by MrPenguin »
ZoomBoy81 wrote:
Sat Oct 11, 2025 4:14 pm
Thank you for looking.
MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_BD66.tgz
coffee70
Post by coffee70 »
works with latest cfg file thanks
Assmonkey
Post by Assmonkey »
I have the latest KEYDB.cfg file and am still met with this:
DEBUG: Code 2147483648 at 3}LEXDFfdV,&S#:f:121265499
003332:0000 Saved AACS dump file as file://C:\Users\MyUserName/.MakeMKV/MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_BD66.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at K/7I6&O",`|u5 8d:213132721
001003:0020 DEBUG: Code 0 at K/7I6&O",`|u5 8d:121263084
MrPenguin
Post by MrPenguin »
Assmonkey wrote:
Sun Oct 12, 2025 7:26 am
Given that KEYDB.cfg does already contain your disk's key, I can only suggest either:
  1. Your UHD drive has not yet enabled LibreDrive.
  2. You have not copied your KEYDB.cfg file to MakeMKV's data directory (i.e. "C:\Users\MyUserName/.MakeMKV" in your case).
  3. Your KEYDB.cfg file cannot be read for some reason, e.g. typo with its file name, incorrect file permissions etc.
