9 semaines et demie UHD Volume Key missing - dump sent
brurab
Purchasing the UHD disk "9 semaines et demie" (French version of "9 1/2 weeks"), I got the error message : "Volume Key missing" - I sent the dump 3 days ago. Any of you has the same issue. Waiting for the key to be added. Thanks for the help.
MrPenguin
Re: 9 semaines et demie UHD Volume Key missing - dump sent
Could you also upload this file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too.brurab wrote: Sat Oct 11, 2025 8:02 am Purchasing the UHD disk "9 semaines et demie" (French version of "9 1/2 weeks"), I got the error message : "Volume Key missing" - I sent the dump 3 days ago. Any of you has the same issue. Waiting for the key to be added. Thanks for the help.
