Please add key to decrypt rip this disc.
RAMBO_FIRST_BLOOD_PART_II_4K
RAMBO II (UHD BD) Polish release (from Rambo Trilogy 3-discs)
Rambo I, and Rambo III discs, decrypted ripped without any problem, only problem with Rambo II.
Drive PIONEER_BD-RW__BDR-S11JX_1.53
Thank you.
RAMBO_FIRST_BLOOD_PART_II_4K (Rambo Trilogy - Polish ver.) - The volume key is unknown for this disc
PeterMac
PeterMac
MrPenguin
Re: RAMBO_FIRST_BLOOD_PART_II_4KUHD - The volume key is unknown for this disc
Could you also upload this TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too. (This isn't guaranteed to work if you have a Pioneer drive, but is still worth trying anyway.)PeterMac wrote: Thu Oct 09, 2025 12:18 pm Please add key to decrypt rip this disc.
PeterMac
@MrPenguin - Thank you!, sure here are log and tgz file.
log
https://drive.google.com/file/d/1KQNZAd ... sp=sharing
tgz
https://drive.google.com/file/d/1S1wcqZ ... sp=sharing
log
tgz
MrPenguin
Could you also provide the MKB_RO.inf file from the physical UHD disk please? The MKB_RO.inf file inside your TGZ dump has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV.
Also, could you recreate this TGZ dump file using your ASUS BW-16D1HT instead of your Pioneer BDR-S11JX please? The Powers That KEYDB cannot read all of the necessary information from dumps created by Pioneer drives, but your ASUS drive should be usable
PeterMac
Here is MKB_RO.inf directly from this disc
https://drive.google.com/file/d/1OHOdSw ... sp=sharing
From Asus drive
log
https://drive.google.com/file/d/1o2hRfY ... sp=sharing
tgz
https://drive.google.com/file/d/1vLICKr ... sp=sharing
From Asus drive
log
tgz
MrPenguin
Thanks for these. I see that KEYDB.cfg contains a partial entry for this disk already, but I am worried that the entry's Unit Key may be incorrectPeterMac wrote: Thu Oct 09, 2025 5:29 pm Here is MKB_RO.inf directly from this disc
From Asus drive
log, tgz
PeterMac
Re: RAMBO_FIRST_BLOOD_PART_II_4K (Rambo Trilogy - Polish ver.) - The volume key is unknown for this disc
Thank you! for checking this everything, I'm really appreciate.
Validating disc...
21:53:11 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
21:53:12 - MODE: ValidateDisc
21:53:12 - DriveLetter : I
21:53:12 - SettingsFile: >C:\Users\Piotr\Desktop\FindVUK\config\FindVUK.ini<
21:53:12 - Logfile >C:\Users\Piotr\Desktop\FindVUK\log\2025-10-09_FindVUK.txt< Default Loglevel >2<
21:53:12 - Update enabled - check for update
21:53:12 - No update required
21:53:12 - Open Main-KEYDB file: >C:\Users\Piotr\AppData\Roaming\aacs\KEYDB.cfg<
21:53:12 - Open Backup-KEYDB file: >C:\Users\Piotr\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
21:53:12 - Get basic AACS data
21:53:12 - AACS folder on disc is reachable - Validate is possible
21:53:13 - VolumeName >RAMBO_FIRST_BLOOD_PART_II_4K<
21:53:13 - DiscId >8A131484D687F975D96F0EDFF6BE222EFB8B4C92< (2022-09-13)
21:53:13 - DiscType >UHD<
21:53:14 - MKB Revision >70<
21:53:14 - Disc-BusEncEnabled >1<
21:53:14 - Drve-BusEncCapable >1<
21:53:14 - ==> Bus Encryption active!
21:53:14 - UnitKeyCount >1<
21:53:14 - >>> UnitKeyENC (1) >2A320B8E5CFCD3E20FC8F5A3A4D08AE1<
21:53:14 - No entry for discid >8A131484D687F975D96F0EDFF6BE222EFB8B4C92< available in keydb >C:\Users\Piotr\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
21:53:14 - Eject the disc now from drive >I:\<
21:53:17 - Successfully ejected the media in drive I!
PeterMac
Disc Info:
Getting disc info...
Validation Data: F8FAF23539C82DD0B0033252D9B986EB [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0x8A131484D687F975D96F0EDFF6BE222EFB8B4C92
[Volume]: RAMBO_FIRST_BLOOD_PART_II_4K
[Title]: RAMBO_FIRST_BLOOD_PART_II_4K
[Date]: 2022-09-13
[VID]: 0xB4D63F91B349525C17720925BB0420DF
[MKB]: 70
[EncKey]: 1-0x2A320B8E5CFCD3E20FC8F5A3A4D08AE1
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: UHD
MrPenguin
Could you check your PM please?
PeterMac
Thank you! I will check and give you feedback
