RAMBO_FIRST_BLOOD_PART_II_4K (Rambo Trilogy - Polish ver.) - The volume key is unknown for this disc
PeterMac
Post by PeterMac »
Please add key to decrypt rip this disc.
RAMBO II (UHD BD) Polish release (from Rambo Trilogy 3-discs)
Rambo I, and Rambo III discs, decrypted ripped without any problem, only problem with Rambo II.
Drive PIONEER_BD-RW__BDR-S11JX_1.53
Thank you.
Re: RAMBO_FIRST_BLOOD_PART_II_4KUHD - The volume key is unknown for this disc
Did you email the dump file to svq@makemkv.com?
UHD FAQ
PeterMac
Post by PeterMac »
Yes
MrPenguin
Post by MrPenguin »
PeterMac wrote:
Thu Oct 09, 2025 12:18 pm
Could you also upload this TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file too. (This isn't guaranteed to work if you have a Pioneer drive, but is still worth trying anyway.)
MrPenguin
Post by MrPenguin »
PeterMac wrote:
Thu Oct 09, 2025 3:08 pm
@MrPenguin - Thank you!, sure here are log and tgz file.
Could you also provide the MKB_RO.inf file from the physical UHD disk please? The MKB_RO.inf file inside your TGZ dump has been truncated to only 56 bytes, which makes it useless to anyone except MakeMKV.
Also, could you recreate this TGZ dump file using your ASUS BW-16D1HT instead of your Pioneer BDR-S11JX please? The Powers That KEYDB cannot read all of the necessary information from dumps created by Pioneer drives, but your ASUS drive should be usable :).
MrPenguin
Post by MrPenguin »
PeterMac wrote:
Thu Oct 09, 2025 5:29 pm
Here is MKB_RO.inf directly from this disc
From Asus drive
log, tgz
Thanks for these. I see that KEYDB.cfg contains a partial entry for this disk already, but I am worried that the entry's Unit Key may be incorrect :(. Can you use SamuriHL's utility to validate your disk against it please? The only practical way to "fix" an incorrect Unit Key is to replace it with a validated one.
PeterMac
Re: RAMBO_FIRST_BLOOD_PART_II_4K (Rambo Trilogy - Polish ver.) - The volume key is unknown for this disc
Post by PeterMac »
Thank you! for checking this everything, I'm really appreciate.
Validating disc...
21:53:11 - ----------- FindVUK 1.82 -----------
To close FindVUK simply press the ESC key
21:53:12 - MODE: ValidateDisc
21:53:12 - DriveLetter : I
21:53:12 - SettingsFile: >C:\Users\Piotr\Desktop\FindVUK\config\FindVUK.ini<
21:53:12 - Logfile >C:\Users\Piotr\Desktop\FindVUK\log\2025-10-09_FindVUK.txt< Default Loglevel >2<
21:53:12 - Update enabled - check for update
21:53:12 - No update required
21:53:12 - Open Main-KEYDB file: >C:\Users\Piotr\AppData\Roaming\aacs\KEYDB.cfg<
21:53:12 - Open Backup-KEYDB file: >C:\Users\Piotr\Desktop\FindVUK\VUKbackup\KEYDB.cfg<
21:53:12 - Get basic AACS data
21:53:12 - AACS folder on disc is reachable - Validate is possible
21:53:13 - VolumeName >RAMBO_FIRST_BLOOD_PART_II_4K<
21:53:13 - DiscId >8A131484D687F975D96F0EDFF6BE222EFB8B4C92< (2022-09-13)
21:53:13 - DiscType >UHD<
21:53:14 - MKB Revision >70<
21:53:14 - Disc-BusEncEnabled >1<
21:53:14 - Drve-BusEncCapable >1<
21:53:14 - ==> Bus Encryption active!
21:53:14 - UnitKeyCount >1<
21:53:14 - >>> UnitKeyENC (1) >2A320B8E5CFCD3E20FC8F5A3A4D08AE1<
21:53:14 - No entry for discid >8A131484D687F975D96F0EDFF6BE222EFB8B4C92< available in keydb >C:\Users\Piotr\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
21:53:14 - Eject the disc now from drive >I:\<
21:53:17 - Successfully ejected the media in drive I!
PeterMac
Post by PeterMac »
Disc Info:
Getting disc info...
Validation Data: F8FAF23539C82DD0B0033252D9B986EB [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0x8A131484D687F975D96F0EDFF6BE222EFB8B4C92
[Volume]: RAMBO_FIRST_BLOOD_PART_II_4K
[Title]: RAMBO_FIRST_BLOOD_PART_II_4K
[Date]: 2022-09-13
[VID]: 0xB4D63F91B349525C17720925BB0420DF
[MKB]: 70
[EncKey]: 1-0x2A320B8E5CFCD3E20FC8F5A3A4D08AE1
[KEYDB_STATUS]:
[STATUS]: not found
[DiscType]: UHD
MrPenguin
Post by MrPenguin »
PeterMac wrote:
Thu Oct 09, 2025 8:02 pm
Disc Info:
Could you check your PM please?
PeterMac
Post by PeterMac »
Thank you! I will check and give you feedback
