the following is what info I get when attempting to open disc:
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?o+IZXkFpXFGixm...
Saved AACS dump file as C:\Users\storm/.MakeMKV/MKB_v82_Nobody_2_CF48.tgz
using latest version 1.18.2, java 1.8.0_461 (latest)
blu-ray Nobody 2
Re: blu-ray Nobody 2
The standard process is the first point below:kahasm wrote: Thu Oct 09, 2025 3:28 am the following is what info I get when attempting to open disc:
- Email the generated tgz dump file to svq@makemkv.com so that MakeMKV can derive the key and add it to their internal hashed keys.
- So now that you have emailed the dump, if you also would like to help the community, first download the latest public KeyDB zip file and extract it to the MakeMKV data directory (where the dumps are locted). After doing this, if you still cannot rip the disc, make a post providing:
- the drive model used to create the dump file.
- the full name of the dump file.
- a download link for the dump file after you have hosted it somewhere.
Qwonset The Hutt
Jabba, you ff, stop stalking me or I'll tell mom.
Qwonset The Hutt
Ha! I assumed it wasn't there yet. Thx!
BobAnalouge
The latest KeyDB file was able to decrypt the US/Canada release of Nobody 2.
Does anyone have a download link handy to the KEYDB? I've not done this method yet but I am also getting this error for this title, a link would be appreciated!
Edit: To be clear the one above 503 errors out. I dont know if you need to request these links each time? If so can I have one made please?
Edit 2: It's now working. Thanks.
chriska416
The latest version of MakeMKV v1.18.2 fixes the issues with this disk.
