Hitman's Wife's Bodyguard 4K
Picked up a used copy from 1/2 books... Couldn't decode it.
Hitman's Wife's Bodyguard 4K #59328.1.A
File sent
File sent
"But I'm just talking out my ass..."
						Re: Hitman's Wife's Bodyguard 4K
Could you also upload this TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB file too.
Thanks, and according to your log file:
003339:0000 Automatic HK downloading is disabled or failed.Re: Hitman's Wife's Bodyguard 4K
Probably my firewall rules. I do have the latest (as in grabbed fresh today) copy of keydb.
Your disc isn't in the KeyDB. Ensure MakeMKV has internet access and try running MakeMKV through a VPN. That usually fixes the HK download issues.
Busy chewing on new Spawn release, will try turning off pihole and starting it back up.
Well, was either my pihole or my region blocking on my firewall, but a brief download later, it is now decrypting the disc.
				leatricekarlie
I’ve tried a few older Lionsgate 4Ks and hit the same kind of decoding wall. Thanks for sharing the dump, maybe this’ll help track down what’s changed.
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?leatricekarlie wrote: ↑Wed Oct 08, 2025 8:09 amI’ve tried a few older Lionsgate 4Ks and hit the same kind of decoding wall. Thanks for sharing the dump, maybe this’ll help track down what’s changed.
If the latest KEYDB.cfg file still doesn't help you then could you upload your TGZ dump files into (say) OneDrive or Google Drive please, and then reply with public download links? This would allow people to try adding your disks to the public KEYDB.cfg file.
