F1 The movie
F1 The movie
Greetings,
Here is my F1 - The movie dump file:
MKB20_v82_F1_C8F4.tgz
https://drive.google.com/file/d/1-gq2Kg ... sp=sharing
MilesMcQueen
Re: F1 The movie
MKB20_v82_F1_0B82.tgz
https://drive.google.com/file/d/1sPP5QX ... sp=sharing
keydb_helper
Re: F1 The movie
The C8F4 and 0B82 variants of F1 have both been added to the public keydb.MilesMcQueen wrote: ↑Thu Oct 02, 2025 12:42 amHere is my F1 - The movie dump file:
Public KeyDB Disc Submissions
Re: F1 The movie
@keydb_helper,
Works like a charm. Thank you
toekneeknows
Re: F1 The movie
I've never done this before but I'm hoping this is correct.
F1 movie dump file here:
MKB20_v82_F1_3AA4.tgz
https://drive.google.com/file/d/1XTQD54 ... sp=sharing
I think I added the latest keydb.cfg to correct folder but this is my first time needing it. Please let me know if I did something wrong.
Re: F1 The movie
The KEYDB.cfg file already contains this disk:toekneeknows wrote: ↑Tue Oct 07, 2025 9:09 pmMKB20_v82_F1_3AA4.tgz
0x86BA6C79B9BFF8BA368FFC92C213E2090C68BAF6 = F1 (F1) | D | 2025-07-28 | ...Have you considered using SamuriHL's utility?
Re: F1 The movie
Is there a way to search for disks in the database before downloading the file? When I'm waiting on a new disk to be added, I'd love to be able to just search existing entries instead of compulsively downloading the file every couple of hours, especially since it downloads really slowly.MrPenguin wrote: ↑Tue Oct 07, 2025 11:12 pmThe KEYDB.cfg file already contains this disk:...Code: Select all
Re: F1 The movie
Try using SamuriHL's utility, which uses FindVUK to "refresh" your copy of KEYDB.cfg rather than redownloading the whole thing each time.
Re: F1 The movie
Yeah, as Mr Penguin said, using SamuriHL's utility is the easiest option. It does have a search function. Just feed it the discID (the SHA-1 of the Unit_Key_RO.inf file on the disc or in the dump) or you can manually download the latest KeyDB, open it in notepad and search for the discID.ttnicky wrote: ↑Tue Oct 07, 2025 11:15 pmIs there a way to search for disks in the database before downloading the file? When I'm waiting on a new disk to be added, I'd love to be able to just search existing entries instead of compulsively downloading the file every couple of hours, especially since it downloads really slowly.MrPenguin wrote: ↑Tue Oct 07, 2025 11:12 pmThe KEYDB.cfg file already contains this disk:...Code: Select all
Re: F1 The movie
Excellent, thank you both! For submitting new dumps (I have a day 1 release waiting for me at home), do we just make a new thread for the movie or is there a dump thread that is preferred? (After making sure the dump is needed, of course).
Re: F1 The movie
Disc Info is easiest.
-Synchronize to pull the latest KeyDB with FindVUK (It does a delta pull so you're only pulling what you're missing and not the whole thing)
-Disc Info
That will tell you the status of your disc. Bonus points for validating unvalidated KeyDB entries while you're at it. This can also be done on protected ISO images in lieu of the physical disc to save time and wear and tear. Just mount it with your favorite image mounting software and Disc Info away.
-Disc Info
Re: F1 The movie
Is Disc Info a part of your utility, or a separate app? I was doing it the old fashioned way of manually downloading the DB file from FindVUK and moving it into my MakeMKV folder and hoping my new disks worked. Rinse and repeat until the disks had finally been added.SamuriHL wrote: ↑Tue Oct 07, 2025 11:54 pmDisc Info is easiest.
-Disc Info
Re: F1 The movie
It's a button in my UI, yes. I prefer 2 button clicks to a lot of manual work, personally...hence why I wrote it.ttnicky wrote: ↑Wed Oct 08, 2025 12:01 am
Re: F1 The movie
Haha, sounds good to me!! I'll be downloading your app tonightSamuriHL wrote: ↑Wed Oct 08, 2025 1:58 amIt's a button in my UI, yes. I prefer 2 button clicks to a lot of manual work, personally...hence why I wrote it.ttnicky wrote: ↑Wed Oct 08, 2025 12:01 am
Is Disc Info a part of your utility, or a separate app? I was doing it the old fashioned way of manually downloading the DB file from FindVUK and moving it into my MakeMKV folder and hoping my new disks worked. Rinse and repeat until the disks had finally been added.![]()
toekneeknows
Re: F1 The movie
thank you. I had it in the wrong folder. All is working nowMrPenguin wrote: ↑Tue Oct 07, 2025 11:12 pmThe KEYDB.cfg file already contains this disk:Just copy your KEYDB.cfg file into the same directory where MakeMKV writes its TGZ dump files, and then restart MakeMKV.Code: Select all
