AACS v82 dump
nik4nao
AACS v82 dump
#1 Post by nik4nao » Sat Oct 04, 2025 5:37 pm
I tried to open this disc with MakeMKV and got the following message:
This disc uses newer version of AACS protection.
Saved AACS dump file as C:\Users\<username>/.MakeMKV/MKB_v82_TBXK_1405_B94A.tgz
The volume key is unknown for this disc - video can't be decrypted.
Backup failed.
Dump file attached.
Re: AACS v82 dump
#2 Post by Woodstock » Sun Oct 05, 2025 3:18 pm
Did you email the file to svq@makemkv.com ? Otherwise, it will not be added to MakeMKV's configuration.
Attaching the file (which didn't work; is it bigger than 4.0mb?) is for the keydb people. Most people upload those to a public storage site (google is popular) and provide a link in the message, rather than attaching a file.
nik4nao
Re: AACS v82 dump
#3 Post by nik4nao » Mon Oct 06, 2025 10:41 am
Woodstock wrote: Sun Oct 05, 2025 3:18 pm Did you email the file to svq@makemkv.com ? Otherwise, it will not be added to MakeMKV's configuration.
Thank you for the reply!
I just emailed them the file. Didn't notice the file didn't actually get uploaded here.
I guess I just have to wait until it's patched.
Thank you again!
MrPenguin
Re: AACS v82 dump
#4 Post by MrPenguin » Mon Oct 06, 2025 2:11 pm
nik4nao wrote: Mon Oct 06, 2025 10:41 am I just emailed them the file. Didn't notice the file didn't actually get uploaded here.
Alternatively, you could upload your TGZ dump file into (say) OneDrive or Google Drive, and then reply with a public download link. This would allow people to try adding your disk to the public KEYDB.cfg file as well.
nik4nao
Re: AACS v82 dump
#5 Post by nik4nao » Thu Oct 09, 2025 4:23 pm
MrPenguin wrote: Mon Oct 06, 2025 2:11 pm
Thank you for the suggestion! I am pretty new in this.
Just uploaded the TGZ dump file here in Google Drive, made it public (tested in private tab)
https://drive.google.com/file/d/1Fsvlbk ... sp=sharing
