AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
mickhyperion
Post by mickhyperion » Sun Oct 05, 2025 8:40 am
The new Hanna-Barbera Touché Turtle and Dum Dum discs are encoded with AACS v82 and MakeMKV says: "The volume key is unknown for this disc - video can't be decrypted."
I have sent the dump files for both discs to svq@makemkv.com and have posted them to Google Drive:
https://drive.google.com/file/d/1e382Yn ... share_link
https://drive.google.com/file/d/1ScclJN ... share_link
Thanks for your help!
MrPenguin
Re: AACS v82 submission - Touché Turtle and Dum Dum (Hanna-Barbera)
Post by MrPenguin » Sun Oct 05, 2025 3:58 pm
Can you adjust the "Share" option on both those files please, so that people can access them?
mickhyperion
Post by mickhyperion » Sun Oct 05, 2025 6:03 pm
Thanks! Those have been made shareable for all now.
MrPenguin
Post by MrPenguin » Sun Oct 05, 2025 7:55 pm
"Touché away!!!!!" :mrgreen:
fschief
Post by fschief » Mon Oct 06, 2025 11:46 pm
Here because I had the same issue. Watching in the hopes of finding a solution.
mickhyperion
Post by mickhyperion » Sat Oct 11, 2025 11:20 pm
Thanks MrPenguin and anyone else who helped. The latest keydb.cfg file did the trick!
Corey B
Post by Corey B » Sun Oct 12, 2025 1:27 pm
Is there a working as of yet? Still getting a failure to read disc.
Thanks for any help, and yes I too have sent submission.
MrPenguin
Post by MrPenguin » Sun Oct 12, 2025 2:56 pm
AFAIK the latest KEYDB.cfg file contains the keys for:
  • MKB_v82_TOUCHE_TURTLE_AND_DUM_DUM_D1_88A4.tgz
  • MKB_v82_TOUCHE_TURTLE_AND_DUM_DUM_D2_3428.tgz
If your dumps have the same variant codes (i.e. 88A4 and 3428) then downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV should work.
If your variant codes are different then could you upload your dumps into (say) OneDrive or Google Drive please, and then reply with public download links?
Corey B
Post by Corey B » Sun Oct 12, 2025 4:12 pm
Tried these discs with the latest KEYDB.cfg file and it still fails
https://drive.google.com/file/d/1vOtsoh ... drive_link
https://drive.google.com/file/d/1sso_HW ... drive_link
Please thank you for any help
Corey B
Post by Corey B » Sun Oct 12, 2025 4:14 pm
Sorry have done all of that and still fails.
Corey B
Post by Corey B » Sun Oct 12, 2025 4:44 pm
Only way for this to work is to uncheck Decrypt which I've never had to do before. Hopefully it still works.
Corey B
Post by Corey B » Sun Oct 12, 2025 5:04 pm
Yes I have the same codes. Apparently they are no longer working unfortunately. And ripping undecrypted results in non playable discs. So no solution currently.
MrPenguin
Post by MrPenguin » Sun Oct 12, 2025 5:32 pm
Can you change the "Share" option for those files please, so that people can access them?
Corey B
Post by Corey B » Sun Oct 12, 2025 5:41 pm
All apologies access granted to all
MrPenguin
Post by MrPenguin » Sun Oct 12, 2025 5:57 pm
You have the exact same disks as the original poster, and the keys are indeed in the latest KEYDB.cfg file. See:
0xC689B8479B0EFFD09643A2D9992FEB7C6294754F = TOUCHE TURTLE AND DUM DUM D1 (TOUCHE TURTLE AND DUM DUM D1) | D | 2025-08-28 | ...
and
0x6A2A96BFDD9B1D4DB7B8B213FE23E80F5ACF7CBA = TOUCHE TURTLE AND DUM DUM D2 (TOUCHE TURTLE AND DUM DUM D2) | D | 2025-08-27 | ...
Your encrypted disk back-ups are almost certainly fine too, they just need a software player capable of decrypting them at runtime, e.g. VLC.
