Public KeyDB Disc Submissions
Post by SamuriHL » Sat Oct 04, 2025 11:27 am
zaqqaz6917 wrote:A_Nightmare_on_Elm_Street_4-_The_Dream_Master_EAFC version
made sure to run Sami's tool
https://www.mediafire.com/file/nwyuzcrn ... C.tgz/file
but just few minutes later it started working and Sami's tool now says key is present
keydb file works for anydvd and XR but doesn't work on Makemkv
Was able to rip with former 2 programs but not MakeMKV v1.18.1
Also manually copied latest keydb to makemkv folder but no joy
No need to manually copy it using my tool. It means the entry for your disc has a unit key but no VUK. Posting the tgz dump was the right thing to do but in the meantime you can use xreveal to decrypt real-time and open the disc with makemkv.
Nokure
Post by Nokure » Sat Oct 04, 2025 12:25 pm
Sorry, the dump file I uploaded did not contain the required files.
zaqqaz6917
Post by zaqqaz6917 » Sat Oct 04, 2025 2:35 pm
SamuriHL wrote: Sat Oct 04, 2025 11:27 am No need to manually copy it using my tool. It means the entry for your disc has a unit key but no VUK. Posting the tgz dump was the right thing to do but in the meantime you can use xreveal to decrypt real-time and open the disc with makemkv.
SamurHL
Thanks for that bit of info.. as said before "Amazing Tool"
I ripped to iso using XR (paid version--always support authors).
Will this rip using a unit key vs using a VUK be any different?
TIA
Post by SamuriHL » Sat Oct 04, 2025 2:43 pm
zaqqaz6917 wrote: Sat Oct 04, 2025 2:35 pm SamurHL
TIA
Nope, it's just about how the disc is decrypted. MakeMKV is still processing it either way.
VixWasHere
Post by VixWasHere » Sat Oct 04, 2025 3:44 pm
Multiple keys for The Transformers: The Movie 4K UHD exist in the database already, but I guess my copy matches none of them.
https://www.dropbox.com/scl/fi/0wur19bz ... oj13o&dl=0
keydb_helper
Post by keydb_helper » Sun Oct 05, 2025 1:30 am
Thanks to everyone who supplied disc dump files. The following disc variants have been added to the public keydb:
MKB20_v76_The_Transformers_The_Movie_BBD1
MKB20_v82_Aeon_Flux_67EA
MKB20_v82_A_Nightmare_on_Elm_Street_4-_The_Dream_Master_EAFC
MKB20_v82_F1_3AA4
MKB20_v82_FREDDYS_DEAD_FINAL_NIGHTMARE_FAF6
MKB20_v82_MISSION-_IMPOSSIBLE_THE_FINAL_RECKONING_9EAA
MKB20_v82_UHD_Memoiren_einer_Schnecke_5262
hardverk wrote: Sat Oct 04, 2025 6:43 pm F1
Hey hardverk, you were fortunate this time that your F1 disc shared a media key with an earlier variant. In the future please use an LG/Asus drive to generate disc dumps for this thread
nobodynothingnowhere
Post by nobodynothingnowhere » Sun Oct 05, 2025 1:57 am
Hi, I have a file for a JP bluray (1st and 2nd disc):
https://transfer.it/t/9IFRWZ1llDRB
MKB_v82_迷宮歌劇「続・美少年探偵団」_C56C.tgz
https://transfer.it/t/Mxle7ckViDAQ
MKB_v82_迷宮歌劇「続・美少年探偵団」_DE50.tgz
Thank you in advance for your help
hardverk
Post by hardverk » Sun Oct 05, 2025 3:14 am
Thanks. I did use my pioneer. Will make sure to use my Asus for dumps going forward.
rjpinca
Post by rjpinca » Sun Oct 05, 2025 5:29 am
MrPenguin wrote: Wed Oct 01, 2025 8:42 pm
gloss wrote: Wed Oct 01, 2025 11:47 am
MrPenguin wrote: Wed Oct 01, 2025 10:45 am
Could you change the "Share" option on this file please, so that people can access it?
Apologies, I was sure that I had. Please try this: https://drive.google.com/file/d/1vNaRrI ... share_link
Heh, yes you did. But rjpinca did not... ;).
Sorry. Sharing access updated!
MrPenguin
Post by MrPenguin » Sun Oct 05, 2025 3:47 pm
rjpinca wrote: Sun Oct 05, 2025 5:29 am Sorry. Sharing access updated!
Thanks, I think your disk is already in the KEYDB.cfg file, so all you should need do is download it, copy it into MakeMKV's data directory (i.e. where MAkeMKV also writes its TGZ dump files) and then restart MakeMKV.
Alternatively, if you're running Windows then you could try using SamuriHL's helper utility to simplify the process.
zaqqaz6917
Post by zaqqaz6917 » Sun Oct 05, 2025 11:35 pm
MKB20_v76_Mortal_Kombat_5965
This is the Mortal Kombat(2021) USA steelbook released on 10-5-2025
is less than 30 kb so added the MKB file
https://www.mediafire.com/file/6ypp0n4s ... 5.rar/file
SamiH tool info
18:18:30 - UnitKeyCount >1<
18:18:30 - >>> UnitKeyENC (1) >2C759A580FB5B3E849E42559F51A2ABF<
18:18:30 - No entry for discid >C74D89F12824BA65996A0E7A18FEB4A6E58AA4FA< available in keydb >C:\Users\PRIME2024\AppData\Roaming\aacs\KEYDB.cfg< - no validation possible!
18:18:30 - Eject the disc now from drive >B:\<
Post by MartyMcNuts » Mon Oct 06, 2025 12:00 am
zaqqaz6917 wrote: Sun Oct 05, 2025 11:35 pm MKB20_v76_Mortal_Kombat_5965
SamiH tool info
A record for this disc has now been added to the public KeyDB. :D
99gagamel
Post by 99gagamel » Mon Oct 06, 2025 10:05 am
High Tension 4k UHD Plaion Mediabook G2 (24. Aug. 2023) Make Error
MKB20_v76_High_Tension_0EB7.tgz
https://drive.google.com/file/d/1ENoOz_ ... sp=sharing
MrPenguin
Post by MrPenguin » Mon Oct 06, 2025 10:51 am
99gagamel wrote: Mon Oct 06, 2025 10:05 am High Tension 4k UHD Plaion Mediabook G2 (24. Aug. 2023) Make Error
Could you also provide the (zipped) AACS/MKB_RO.inf file from your physical UHD disk please? The copy of this file inside your TGZ dump file has been truncated to only 56 bytes, which makes it useless to anyone other than MakeMKV itself.
