Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
maczrool
Re: Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
Post by maczrool »
MrPenguin wrote: Sat Sep 27, 2025 12:34 pm
OK, could you upload that TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link?
Thanks. Here it is: https://1drv.ms/u/c/0bdc58ecdb7f6a52/EQ ... Q?e=YEd0LD.
keydb_helper
Post by keydb_helper »
maczrool wrote: Sat Sep 27, 2025 1:08 pm Thanks. Here it is: ...
Edit: Sorry for the confusion, there are at least three UHD variants of this title...
Public KeyDB Disc Submissions
maczrool
Post by maczrool »
keydb_helper wrote: Sat Sep 27, 2025 1:13 pm Your disc was added to the public keydb about 12 hours ago. Open up your keydb.cfg file in a text editor and search for 0x97F76C5A117EFD83D5A1848DB7D3A29B1F161622. If you can't see it, download the latest keydb
Edit: Someone submitted the wrong VUK to the public keydb for your disc variant... That may take some time to get corrected
Thanks, I'll just wait.
keydb_helper
maczrool wrote: Sat Sep 27, 2025 1:29 pm Thanks, I'll just wait.
Now you should be good to go with the latest keydb.
When checking the status of your disc I accidentally mixed up the actual libaacs disc ID (0x97F76C5A117EFD83D5A1848DB7D3A29B1F161622) with a different variant of the same movie (0x9F46BFE7CB0B2CD796EA36A2930F82FD7AB730F2).
They share a media key but I should've read past the first 4 bits when comparing the disc ID values...
maczrool
Post by maczrool »
keydb_helper wrote: Sat Sep 27, 2025 1:48 pm Now you should be good to go with the latest keydb.
Yep, it's working now. Thanks so much!
rogueranger89
Post by rogueranger89 »
A nightmare on Elm Street 7 movie set UHD & Blu-Ray (Germany)
Nightmare 1-5 work when first decoding with "Xreveal"
Nightmare 6 & 7 didn't so i've sent the dump files via e-mail.
MKB20_v82_FREDDYS_DEAD_FINAL_NIGHTMARE_FAF6 :
https://1drv.ms/f/c/6191de0a61c46047/El ... g?e=ciqAmA
MKB20_v82_WES_CRAVENS_NEW_NIGHTMARE_739E.tgz : https://1drv.ms/f/c/6191de0a61c46047/Es ... w?e=f0ydXz
UnclejoshC
Post by UnclejoshC »
Thank you for this!
MrPenguin
Post by MrPenguin »
rogueranger89 wrote: Sat Oct 04, 2025 4:56 pm Nightmare 1-5 work when first decoding with "Xreveal"
While its's great that you've managed to decrypt these using Xreveal, Xreveal only works on Windows :(. However, if you could also provide these TGZ dump files (as you already have for disks 6 and 7) then we could also add full support to KEYDB. This would allow non-Windows users to decode these disks too :).
rogueranger89
@MrPenguin way ahead of you :D i just did the others.
Yeah having it in the keydb. file is better. Even on Windows XReveal is a "works sometimes" solution.
here are the other files
MKB20_v77_NIGHTMARE_ON_ELM_STREET_371B :
https://1drv.ms/f/c/6191de0a61c46047/Ev ... w?e=6P5rJh
MKB20_v82_NIGHTMARE_ON_ELM_STREET2_55FC :
https://1drv.ms/f/c/6191de0a61c46047/Et ... g?e=Ho94bK
MKB20_v82_A_NIGHTMARE_ON_ELM_STREET_3_9DFE :
https://1drv.ms/f/c/6191de0a61c46047/Et ... A?e=WPzfrN
MKB20_v82_NIGHTMARE_ON_ELM_STREET4_F7D0 :
https://1drv.ms/f/c/6191de0a61c46047/Em ... w?e=a51hsN
MKB20_v82_NIGHTMARE_ON_ELM_STREET5_D4BC :
https://1drv.ms/f/c/6191de0a61c46047/Et ... w?e=nsXili
