https://drive.google.com/file/d/1llJiRi ... drive_link
The Last Rodeo
Public KeyDB Disc Submissions
ncbreezy
htfancub
MrPenguin
Could you change this file's "Share" option please, so that people can access it?
Nokure
Hello.
I have a key dump file for a standard (non-UHD) Blu-ray. Could you please add it to the public key database?
https://1drv.ms/f/c/9b09033a7cd65096/El ... Q?e=KDQsfd
MKB_v82_unkn0wn_E2AC.tgz
MKB_v82_unkn0wn_6B16.tgz
This is a dump file of a disk that has different contents written to it, but the contents may be the same.
MrPenguin
Have you configured these objects to that anyone can download them?
Nokure
Hello MrPenguin.
Yes, I think it's set up so that anyone can download it, but is it still not possible to download it?
MrPenguin
"Something went wrong. We're having some trouble. Please try again later."Nokure wrote: Fri Oct 03, 2025 10:58 pm Yes, I think it's set up so that anyone can download it, but is it still not possible to download it?
Nokure
Sorry, I was able to access it without signing in to OneDrive.
I tried uploading the same file to Google Drive.
Can you access it now?
hardverk
scarbrtj
keydb_helper
Hey scarbrtj, thanks for the new disc dump. The 4A24 variant of Miyakao Island has been submitted to the public keydb.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
zaqqaz6917
A_Nightmare_on_Elm_Street_4-_The_Dream_Master_EAFC version
made sure to run Sami's tool
https://www.mediafire.com/file/nwyuzcrn ... C.tgz/file
but just few minutes later it started working and Sami's tool now says key is present
keydb file works for anydvd and XR but doesn't work on Makemkv
Was able to rip with former 2 programs but not MakeMKV v1.18.1
Also manually copied latest keydb to makemkv folder but no joy
perfectdirt
Memoirs of a snail
4K UHD German Mediabook
MKB20_v82_UHD_Memoiren_einer_Schnecke_5262.tgz
https://drive.google.com/file/d/1Ev8sOs ... sp=sharing
MrPenguin
Thanks, but unfortunately your two TGZ dump files do not contain any usable information
