Silly bugger! Updating firmware doesn’t help with reading discs. Updates really only ever help with writing discs and as far as UHD is concerned, causes nothing but issues, as you now know….impala454 wrote: Wed Oct 01, 2025 1:43 amOh no! I am in this same boat. I've had this drive forever and recently got back to ripping my collection. I've had several discs fail (well, maybe 4-5 discs out of 100 or so so far) so I thought I'd go update the drive's firmware and see if that helped. Now I'm on 1.04 (same drive as @DavidLai).Coopervid wrote: Tue Sep 30, 2025 6:21 pmYour firmware is too new. You have to wait until Mike comes up with a solution. No ETA.DavidLai wrote: Tue Sep 30, 2025 4:59 pm
OK, here it is.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CGDL002072UC
Firmware date: 2022-12-27
Highest AACS version: 81
Drive platform: Pioneer RS9331
Firmware version: ID05
LibreDrive for Pioneer drives
Well, it's safe to say that this will be the first and only time I'll purchase a UHD Blu-Ray disk. I thought I had future-proofed myself 3 years ago when I bought the UHD drive, only to find out this past weekend that it doesn't work. Hopefully a solution will come soon. You guys are a group of very knowledgeable people, that's really good. Thanks for answering my question, and I'll continue to check here for any updates.
I think you have the choice of waiting for Mike to do his thing, presuming you have a Pioneer drive, or buy a drive from one of the suppliers here.DavidLai wrote: Wed Oct 01, 2025 8:54 pm Well, it's safe to say that this will be the first and only time I'll purchase a UHD Blu-Ray disk. I thought I had future-proofed myself 3 years ago when I bought the UHD drive, only to find out this past weekend that it doesn't work. Hopefully a solution will come soon. You guys are a group of very knowledgeable people, that's really good. Thanks for answering my question, and I'll continue to check here for any updates.
Yeah. I'll just wait for Mike, as the Pioneer drive I purchased 3 years ago still works fine otherwise. It would be a pitty to have to make space for another drive in my limited space.
DavoBR wrote: Wed Oct 01, 2025 9:39 pmI think you have the choice of waiting for Mike to do his thing, presuming you have a Pioneer drive, or buy a drive from one of the suppliers here.DavidLai wrote: Wed Oct 01, 2025 8:54 pm Well, it's safe to say that this will be the first and only time I'll purchase a UHD Blu-Ray disk. I thought I had future-proofed myself 3 years ago when I bought the UHD drive, only to find out this past weekend that it doesn't work. Hopefully a solution will come soon. You guys are a group of very knowledgeable people, that's really good. Thanks for answering my question, and I'll continue to check here for any updates.
I got Pioneer BDRXS07TUHD - firmware 1.03. It possible to rip UHD Disc?
post the makemkv drive info section makes it alot easier to telldavester wrote: Sat Oct 04, 2025 4:14 am I got Pioneer BDRXS07TUHD - firmware 1.03. It possible to rip UHD Disc?
Do folks just wait for the update to happen or is there a specific thread to follow here that he'd post on if/when that time comes?DavoBR wrote: Wed Oct 01, 2025 9:39 pmI think you have the choice of waiting for Mike to do his thing, presuming you have a Pioneer drive, or buy a drive from one of the suppliers here.
Well, most likely either this very thread or this thread: viewtopic.php?f=16&t=37848impala454 wrote: Sat Oct 04, 2025 5:18 pmDo folks just wait for the update to happen or is there a specific thread to follow here that he'd post on if/when that time comes?DavoBR wrote: Wed Oct 01, 2025 9:39 pmI think you have the choice of waiting for Mike to do his thing, presuming you have a Pioneer drive, or buy a drive from one of the suppliers here.
Drive cannot play uhd:
Product: BD-RW BDR-S12U
Revision: 1.04
Serial number:
Firmware date: 2022-12-20
Highest AACS version: 61
Drive platform: Pioneer RS8F01
Firmware version: ID43
Revision: 1.04
Serial number:
Any firmware dated after 11/2022 is not UHD compatible and cannot be downgraded.
You have to wait until Mike comes up with a solution for which there is currently no timeline.
However, Mike has at least stated that a solution exists for all such Pioneer drivesDavoBR wrote: Mon Oct 06, 2025 1:26 pm You have to wait until Mike comes up with a solution for which there is currently no timeline.
So a 2-year-old firmware still hasn't gotten supported, that's sad to hear. I'm still holding out hope, though the hope is slim.
MrPenguin wrote: Mon Oct 06, 2025 2:32 pmHowever, Mike has at least stated that a solution exists for all such Pioneer drivesDavoBR wrote: Mon Oct 06, 2025 1:26 pm You have to wait until Mike comes up with a solution for which there is currently no timeline.. It's just that no-one has any hint of its ETA.
FWIW there is considerably more hope today than there was 2 years ago...DavidLai wrote: Mon Oct 06, 2025 2:55 pm So a 2-year-old firmware still hasn't gotten supported, that's sad to hear. I'm still holding out hope, though the hope is slim.
OS device name: F:
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: DEDL008446WL
Firmware date: 2023-01-06
Bus encryption flags: 13
OS device name: F:
Revision: 1.03
No. As the firmware is post 11/2022, you will have to wait for future support.davester wrote: Tue Oct 07, 2025 12:26 am Drive Information
OS device name: F:
Revision: 1.03
