Tron Legacy Dump Submitted
Ralph P.
Greetings,
MKB20_v77_Tron-_Legacy_34CE
I will also share it on Google Drive for keydb.
Regards,
Regards,
Re: Tron Legacy Dump Submitted
Oh you're so not nice.
I am massively jealous! Glad you submitted it though.
keydb_helper
Thanks Ralph, the 34CE variant of Tron: Legacy has been added to the public keydb.Ralph P. wrote: Thu Sep 11, 2025 6:39 pm Greetings,
Regards,
You should be set now when you receive your copy in early October...SamuriHL wrote: Thu Sep 11, 2025 6:51 pm Oh you're so not nice.I am massively jealous! Glad you submitted it though.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Excuse me? LOL Try September 17.keydb_helper wrote: Fri Sep 12, 2025 2:09 am
Just got mine and thanks to you was already in KeyDB. So thanks!
GFly91
That one's in the keydb.
discid: 0xD96763B54C1C3971E8EFB9EF8777F3412CE7060E
rhett7660
Thank you that was quick!!!
Simbo
MrPenguin
Can you change the "Share" option on that file please, so that people can access it?
Simbo
Galactica-Actual
HI all
I submitted the dump file for the UK 4 kuhd at the weekend. It still wont decrypt. How long does it normally take for the sent dump file to be looked at and a decryption key made? Thanks.
MrPenguin
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Galactica-Actual wrote: Tue Sep 30, 2025 3:28 pm I submitted the dump file for the UK 4 kuhd at the weekend. It still wont decrypt.
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This could allow people to try adding your disk to the KEYDB.
Galactica-Actual
I am sorry, i dont know how to do the things you suggest above. I do know my drive is a pioneer one, which i have been informed limits my options with dump files...is that correct?
ArcadiaHumanoid
KeyDB is working for my copy of MKB20_v77_Tron-_Legacy_5A3CMrPenguin wrote: Tue Sep 30, 2025 3:48 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?Galactica-Actual wrote: Tue Sep 30, 2025 3:28 pm I submitted the dump file for the UK 4 kuhd at the weekend. It still wont decrypt.
