Error Dumps
John Rambo 4k UHD MB:
https://drive.google.com/file/d/1L73vIA ... drive_link
________________________________
12 Geschworenen 4K UHD
https://drive.google.com/file/d/1xkciyB ... drive_link
____________________________________________
The Roundup Punishment 4k UHD
https://drive.google.com/file/d/1Y5zWIV ... drive_link
Public KeyDB Disc Submissions
99gagamel
keydb_helper
Hey Toad King, thanks for the new disc dump. The 20C2 variant of Isle of Dogs has been added to the public keydb.
- Do not submit Stranger Things S2D2, S4D3, or S5D2
MrPenguin
Could you alter the "Share" option on these files please, so that people can access them?99gagamel wrote: Tue Sep 30, 2025 9:13 am John Rambo 4k UHD MB:
herrguerrero
I just downloaded the last version of keydb and now it works like a charm, so many thanks to the team!herrguerrero wrote: Tue Sep 23, 2025 7:31 am Hi, here's my dump file for The Hidden Fortress BFI BluRay
https://drive.google.com/file/d/1IR3ZDN ... sp=sharing
It's strange that both MakeMKV and VLC say that the name of the disc is Sanjuro. I already own that and had no problems playing it, so maybe the system just got confused?
By the way, my player is a Pioneer BDR-XD05S with the last firmware update (v. 3.11). I know that there are issues with those players, but maybe something can be learned from it.
Thanks in advance!
MrPenguin
The link for "John Rambo" here is the same as the one for "12 Geschworenen". Can you provide the actual "John Rambo" link please?99gagamel wrote: Tue Sep 30, 2025 9:13 am John Rambo 4k UHD MB:
https://drive.google.com/file/d/1xkciyB ... sp=sharing
99gagamel
""Könnten Sie bitte die Option „Teilen“ für diese Dateien ändern, damit andere darauf zugreifen können?""
AW:
Sorry, mache das zum ersten mal, hab es geändert... gerne testen. sollte jetzt klappen mit zugriff auf die Dumps
AW:
99gagamel
MrPenguin
Thanks. Have you also emailed these dumps to svq@makemkv.com? You can also try using SamuriHL's tool for Windows to see if your keys are already in the public KEYDB.
kbwyrick
MrPenguin
Doesn't KEYDB.cfg already contain this disk?kbwyrick wrote: Tue Sep 30, 2025 2:22 pm The French Dispatch (Criterion):
MKB20_v82_THE_FRENCH_DISPATCH_E0EE.tgz
kbwyrick
MrPenguin
The key in KEYDB.cfg looks correct. Is your KEYDB.cfg file literally called "KEYDB.cfg", and not "keydb.cfg"? This might be important on MacOS.
99gagamel
Hi, eine email habe ich nicht versendet. In der Anleitung stand nichts davon.MrPenguin wrote: Tue Sep 30, 2025 2:09 pmThanks. Have you also emailed these dumps to svq@makemkv.com? You can also try using SamuriHL's tool for Windows to see if your keys are already in the public KEYDB.
Ich kann den John Rambo Dump aber auch gerne noch an dies "make" eMail senden, wenn es Sinn macht.
SamuriHL's tool habe ich nicht ausprobiert. Aber die öffentliche Key Datei nutze ich.
Sie funktioniert auch. Nur halt bei John Rambo UHD nicht. Daher hab ich den Dump gepostet
MrPenguin
Ich empfehle das Tool von SamuriHL für Benutzer, die Windows verwenden, da es die Verwendung der öffentlichen KEYDB-Datei erleichtert.99gagamel wrote: Tue Sep 30, 2025 8:45 pm Hi, eine email habe ich nicht versendet. In der Anleitung stand nichts davon.
gloss
Dump for The Life of Chuck 4K UHD: https://drive.google.com/file/d/1vNaRrI ... share_link
