Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
rudebox
Post by rudebox »
New 7 Disc Collection UHD for Nightmare on Elm Street
(Sep 30 Release Date, I received today from Gruv)
I just submitted the following 7 dump files to "svq@makemkv.com"
MKB20_v77_A_Nightmare_on_Elm_Street_8A53.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_A154.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_ADC6.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_4-_The_Dream_Master_B884.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_5-The_Dream_Child_2E7E.tgz
MKB20_v82_Freddy's_Dead-_The_Final_Nightmare_E394.tgz
MKB20_v82_Wes_Craven's_New_Nightmare_6F38.tgz
MrPenguin
Re: Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
Post by MrPenguin »
rudebox wrote:
Fri Sep 26, 2025 7:53 pm
rudebox
Post by rudebox »
Thank you so much! That was not something I was not aware of until your reply. I have updated the KEYDB.cfg file now and it seems to have resolved the issue. I'm ripping the first disc successfully now. Tomorrow I'll try the other discs in the set. :D
MrPenguin
Post by MrPenguin »
rudebox wrote:
Fri Sep 26, 2025 11:38 pm
Great :). But have you still emailed those TGZ dump files to svq@makemkv.com, so that MakeMKV can also add your disks to its own hashed keys database?
rudebox
Post by rudebox »
Yep, I sure did. I emailed all 7 to Makemkv earlier so they can add the disks to their database.
maczrool
Post by maczrool »
Only the first one works for me with the latest keydb.cfg file which isn't much help since it's likely the same scan as last year's release. I sent all 7 TGZ files to Mike as well.
keydb_helper
Post by keydb_helper »
maczrool wrote:
Sat Sep 27, 2025 1:04 am
Grab the latest public keydb and you should now be able to process the remaining discs in the set
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
maczrool
Post by maczrool »
keydb_helper wrote:
Sat Sep 27, 2025 3:43 am
Just grabbed it, but still not working past the first. It is installed correctly because without, it won't even decrypt the first disc.
MrPenguin
Post by MrPenguin »
maczrool wrote:
Sat Sep 27, 2025 11:11 am
Do your TGZ dump files have the exact same names as the ones added to KEYDB? If their four-character variant codes differ then they're for different disk variants and so would need separate entries in KEYDB.
keydb_helper
Thanks for checking. Feel free to upload your disc dump files to a file host and post the links to the keydb thread.
maczrool
Post by maczrool »
MrPenguin wrote:
Sat Sep 27, 2025 11:27 am
I am not able to identify the variant codes unfortunately because I don't see any 4 character codes in the key file.
keydb_helper
maczrool wrote:
Sat Sep 27, 2025 12:20 pm
If you can't upload the disc dump files, could you please post the filenames of your disc dump files? These variants were added to the public keydb earlier today (variant id in bold):
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_DD86
MKB20_v82_HOUSE_FRANKENSTEIN_DRACULA_661A
MrPenguin
Post by MrPenguin »
I meant comparing your dumps' file names with those listed earlier in this thread. But if your disks are already included in KEYDB.cfg then I would also expect MakeMKV to be able to decrypt them.
maczrool
Post by maczrool »
MrPenguin wrote:
Sat Sep 27, 2025 12:26 pm
Sorry, it seems they all work except the second one which indeed has a different title from the list posted earlier. The file name is:
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_7B4E
Thanks for your help!
MrPenguin
Post by MrPenguin »
maczrool wrote:
Sat Sep 27, 2025 12:31 pm
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_7B4E.tgz
OK, could you upload that TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link?
