Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
New 7 Disc Collection UHD for Nightmare on Elm Street
(Sep 30 Release Date, I received today from Gruv)
I just submitted the following 7 dump files to "svq@makemkv.com"
MKB20_v77_A_Nightmare_on_Elm_Street_8A53.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_A154.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_ADC6.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_4-_The_Dream_Master_B884.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_5-The_Dream_Child_2E7E.tgz
MKB20_v82_Freddy's_Dead-_The_Final_Nightmare_E394.tgz
MKB20_v82_Wes_Craven's_New_Nightmare_6F38.tgz
Re: Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?rudebox wrote: ↑Fri Sep 26, 2025 7:53 pmMKB20_v77_A_Nightmare_on_Elm_Street_8A53.tgz
Thank you so much! That was not something I was not aware of until your reply. I have updated the KEYDB.cfg file now and it seems to have resolved the issue. I'm ripping the first disc successfully now. Tomorrow I'll try the other discs in the set.
Great
Yep, I sure did. I emailed all 7 to Makemkv earlier so they can add the disks to their database.
Only the first one works for me with the latest keydb.cfg file which isn't much help since it's likely the same scan as last year's release. I sent all 7 TGZ files to Mike as well.
keydb_helper
Grab the latest public keydb and you should now be able to process the remaining discs in the set
Public KeyDB Disc Submissions
Just grabbed it, but still not working past the first. It is installed correctly because without, it won't even decrypt the first disc.keydb_helper wrote: ↑Sat Sep 27, 2025 3:43 am
Do your TGZ dump files have the exact same names as the ones added to KEYDB? If their four-character variant codes differ then they're for different disk variants and so would need separate entries in KEYDB.
keydb_helper
Thanks for checking. Feel free to upload your disc dump files to a file host and post the links to the keydb thread.
I am not able to identify the variant codes unfortunately because I don't see any 4 character codes in the key file.
keydb_helper
If you can't upload the disc dump files, could you please post the filenames of your disc dump files? These variants were added to the public keydb earlier today (variant id in bold):
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_DD86
MKB20_v82_HOUSE_FRANKENSTEIN_DRACULA_661A
I meant comparing your dumps' file names with those listed earlier in this thread. But if your disks are already included in KEYDB.cfg then I would also expect MakeMKV to be able to decrypt them.
Sorry, it seems they all work except the second one which indeed has a different title from the list posted earlier. The file name is:
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_7B4E
Thanks for your help!
OK, could you upload that TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link?
