Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
rudebox
New 7 Disc Collection UHD for Nightmare on Elm Street
(Sep 30 Release Date, I received today from Gruv)
I just submitted the following 7 dump files to "svq@makemkv.com"
MKB20_v77_A_Nightmare_on_Elm_Street_8A53.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_A154.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_ADC6.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_4-_The_Dream_Master_B884.tgz
MKB20_v82_A_Nightmare_on_Elm_Street_5-The_Dream_Child_2E7E.tgz
MKB20_v82_Freddy's_Dead-_The_Final_Nightmare_E394.tgz
MKB20_v82_Wes_Craven's_New_Nightmare_6F38.tgz
MrPenguin
Re: Dumps Submitted (A Nightmare on Elm Street 7 Discs UHD)
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?rudebox wrote: Fri Sep 26, 2025 7:53 pm MKB20_v77_A_Nightmare_on_Elm_Street_8A53.tgz
rudebox
Thank you so much! That was not something I was not aware of until your reply. I have updated the KEYDB.cfg file now and it seems to have resolved the issue. I'm ripping the first disc successfully now. Tomorrow I'll try the other discs in the set.
MrPenguin
Greatrudebox wrote: Fri Sep 26, 2025 11:38 pm Thank you so much! That was not something I was not aware of until your reply. I have updated the KEYDB.cfg file now and it seems to have resolved the issue. I'm ripping the first disc successfully now. Tomorrow I'll try the other discs in the set.![]()
rudebox
Yep, I sure did. I emailed all 7 to Makemkv earlier so they can add the disks to their database.
maczrool
Only the first one works for me with the latest keydb.cfg file which isn't much help since it's likely the same scan as last year's release. I sent all 7 TGZ files to Mike as well.
keydb_helper
Grab the latest public keydb and you should now be able to process the remaining discs in the setmaczrool wrote: Sat Sep 27, 2025 1:04 am Only the first one works for me with the latest keydb.cfg file which isn't much help since it's likely the same scan as last year's release. I sent all 7 TGZ files to Mike as well.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
maczrool
Just grabbed it, but still not working past the first. It is installed correctly because without, it won't even decrypt the first disc.keydb_helper wrote: Sat Sep 27, 2025 3:43 am
MrPenguin
Do your TGZ dump files have the exact same names as the ones added to KEYDB? If their four-character variant codes differ then they're for different disk variants and so would need separate entries in KEYDB.maczrool wrote: Sat Sep 27, 2025 11:11 am Just grabbed it, but still not working past the first. It is installed correctly because without, it won't even decrypt the first disc.
keydb_helper
Thanks for checking. Feel free to upload your disc dump files to a file host and post the links to the keydb thread.maczrool wrote: Sat Sep 27, 2025 11:11 am Just grabbed it, but still not working past the first. It is installed correctly because without, it won't even decrypt the first disc.
maczrool
I am not able to identify the variant codes unfortunately because I don't see any 4 character codes in the key file.MrPenguin wrote: Sat Sep 27, 2025 11:27 am
keydb_helper
If you can't upload the disc dump files, could you please post the filenames of your disc dump files? These variants were added to the public keydb earlier today (variant id in bold):maczrool wrote: Sat Sep 27, 2025 12:20 pm I am not able to identify the variant codes unfortunately because I don't see any 4 character codes in the key file.
MKB20_v82_A_Nightmare_on_Elm_Street_3-_Dream_Warriors_DD86
MKB20_v82_HOUSE_FRANKENSTEIN_DRACULA_661A
MrPenguin
I meant comparing your dumps' file names with those listed earlier in this thread. But if your disks are already included in KEYDB.cfg then I would also expect MakeMKV to be able to decrypt them.maczrool wrote: Sat Sep 27, 2025 12:20 pm I am not able to identify the variant codes unfortunately because I don't see any 4 character codes in the key file.
maczrool
Sorry, it seems they all work except the second one which indeed has a different title from the list posted earlier. The file name is:MrPenguin wrote: Sat Sep 27, 2025 12:26 pm
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_7B4E
Thanks for your help!
MrPenguin
OK, could you upload that TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link?maczrool wrote: Sat Sep 27, 2025 12:31 pm Sorry, it seems they all work except the second one which indeed has a different title from the list posted earlier. The file name is:
MKB20_v82_A_Nightmare_on_Elm_Street_2-_Freddy's_Revenge_7B4E.tgz
