Public KeyDB Disc Submissions
zaqqaz6917
Huge thanks to key db _helper and other involved in updating the file so our disks may be archived.
your efforts can never be repaid.
As an aside I just downloaded SamuriHL's program. It too is awesome....Hit the Synchronize button and it does all the work, all the other features are an added bonus
Just hit synchronize before submitting dump and recheck your disk and voila you have helped these key makers 1000% percent.
I hit synchronize each time before inserting a new disk, to ensure the lates keys are on my pc
Thanks again to all
Thanks again to all
Its "validate" button is equally awesome...zaqqaz6917 wrote: ↑Tue Sep 23, 2025 3:56 pmIt too is awesome....Hit the Synchronize button and it does all the work, all the other features are an added bonus
MykieGuilotine
Sorry for the resubmission then. I did originally submit it, but without the actual MKB_RO.inf. I did sent the MKB_RO.inf separately to the public keydb email too.
The disc info button is super useful. It'll run the validate automatically if it's needed and tells you whether your disc is supported or not. Everyone ideally should be doing this on their discs:
Load up KeyDB Helper
Synchronize
For each disc: Disc Info
That will show you the status of your disc and will also validate it if it needs to be validated.
Synchronize
Warbington
Dump for Aztec Batman (MKB20_v82_Aztec_Batman-_Clash_of_Empires_4AC0)
https://drive.google.com/file/d/1Lw2W3b ... sp=sharing
Thanks for these, but unfortunately your UHD drive has not enabled LibreDrive, which makes these dumps not very usefulpse1122pse wrote: ↑Tue Sep 23, 2025 1:01 pmyour name. UHD (korea)
Weathering With You UHD (korea)
Suzume UHD (korea)
Try again , last post the link are restricted
The last of us part 2 4K UHD
hope this works..
hope this works..
The KEYDB.cfg file already contains all three of these disks, so if you download it and copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) then you should be good to go.
keydb_helper
Hey MKVDUDE, thanks for the new disc dump. The 449E variant of Night of The Living Dead has been added to the public keydb.
Thanks for the disc dump Warbington, the 4AC0 variant of Aztec Batman has been added to the public keydb.Warbington wrote: ↑Tue Sep 23, 2025 5:40 pmDump for Aztec Batman (MKB20_v82_Aztec_Batman-_Clash_of_Empires_4AC0)
Hello!This is a dump of Yakushimaru Hiroko's 2024 Orchestral Concert(Japan)
https://drive.google.com/file/d/127_aCd ... drive_link
Many thanks!
Many thanks!
hello!This is a dump of Yakushimaru Hiroko's 2024 concert(Japan)
many thanks!
many thanks!
Thanks!keydb_helper wrote: ↑Tue Sep 23, 2025 11:45 pm
Can you adjust the "Share" option for your two files please, so that people can access them?
