Alita Battle Angel
csbond2
Alita Battle Angel
Post by csbond2 »
It will not open gives a copy protection warning.
csbond2
Re: Alita Battle Angel
Post by csbond2 »
It will not let me attach a dump file says board quota has been reached
csbond2
Post by csbond2 »
MrPenguin
Post by MrPenguin »
csbond2 wrote:
Tue Sep 09, 2025 6:52 pm
Dump file
I think your disk is already in KEYDB.cfg. The reason you cannot rip it is because your drive has not enabled LibreDrive:
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
csbond2
Post by csbond2 »
MrPenguin wrote:
Tue Sep 09, 2025 7:05 pm
Dump file
The drive is flashed and works on all the disks except this one . In fact i am doing Rise of Skywalker right now.
MrPenguin
Post by MrPenguin »
csbond2 wrote:
Tue Sep 09, 2025 7:08 pm
And yet LibreDrive is still clearly not enabled:
DEBUG: Code 2147483648 at 2g`y)1d*msr{}#Bb:121265499
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2'
Maybe just power-cycle the drive and try again?
csbond2
Post by csbond2 »
MrPenguin wrote:
Tue Sep 09, 2025 7:11 pm
I will try it again here shortly as I said I am in the middle of doing rise of Skywalker right now. I'm sure it might be something simple but anyway I added a dump file just in case.
MrPenguin
Post by MrPenguin »
csbond2 wrote:
Tue Sep 09, 2025 7:14 pm
Unfortunately, your dump file is unusable because LibreDrive was not enabled. However, KEYDB.cfg already has your disk's key and so you will be good to go as soon as you do enable LD.
csbond2
Post by csbond2 »
MrPenguin wrote:
Tue Sep 09, 2025 7:22 pm
That doesn't make any sense. It is enabled I am able to do any disc I want except for that one. As I said I am doing rise of Skywalker right this moment so why would it not enable on that disk. I cannot make it enable when I put the disc in if it doesn't enable there's nothing I can do about it. Drive has been flashed it works on every other disk I've tried that is the first one that will not read and I'm not trying to be a pain but the answer you're giving me isn't giving me any help. When I put the disc in Libra drive is enabled what it does after that I have no control over.
csbond2
Post by csbond2 »
When I get done with this disc I will take a screenshot of it to show you that the drive is enabled. And then I will put the disc in and show you what the screenshot shows when the disc is first analyzed. The problem comes when I hit the button for it to read the disc.
csbond2
Post by csbond2 »
Okay the other one finally finished and I retried it again made sure that the drive was enabled and yes it did decrypt it this time. What I did to disable the drive before I have no clue but anyway thanks for your help.
MrPenguin
Post by MrPenguin »
csbond2 wrote:
Tue Sep 09, 2025 8:06 pm
It could just have been a matter of timing, e.g. trying to access the disk too soon?
On the odd occasion libredrive may not activate, simply close MAkeMKV, power cycle the drive, insert the disc, wait for the OS to initialise the disc, then open up MakeMKV.
