Failed to open for me. emailed dump to svq@makemkv.com yesterday.
MKB_v82_FLAMING_BROTHERS_9A8E.tgz
https://drive.google.com/file/d/1S9fXZa ... sp=sharing
Flaming Brothers Blu-ray AACS v82 dump files
Lostintime
Lostintime
Re: Flaming Brothers Blu-ray AACS v82 dump files
Not sure if it is helpful with non UHD discs but here is a dump from an LG drive, the first one was from a Pioneer.
https://drive.google.com/file/d/1P5FC2x ... sp=sharing
MrPenguin
It's good to know that you have an LG drive as well as a Pioneer drive. FYI you should only need LibreDrive for UHD disks.Lostintime wrote: Wed Sep 03, 2025 6:52 pm Not sure if it is helpful with non UHD discs but here is a dump from an LG drive, the first one was from a Pioneer.
