Public KeyDB Disc Submissions
jemima
FYI: There was some mess up in the online DB on 2025-08-19... diff to the day before shows that for ~ 16670 entries, such encoding corruption happened... I've already PMed nalor about it.keydb_helper wrote: Thu Aug 28, 2025 6:35 am The metadata title of your disc contains the non-ASCII right single quotation mark (UTF-8 encoding 0xE28099). This is why your search for "Knight's Tale" returned nothing - you needed to search for "Knight’s Tale". This is also why the title may render as "Knight’s Tale" if interpreted as ANSI/Windows-1252 text.
Toad King
Dump for Get Carter (MKB20_v82_Get_Carter_-_4K_UHD_C9AE)
https://drive.google.com/drive/u/0/fold ... dVbDomRK9I
NotThatGuy
Got two more discs for the db
The lords of discipline: https://mega.nz/file/mTgxlDQI#SGCp5ncvT ... k-xMsThIV4
This is spinal tap: https://mega.nz/file/ySJGnBTL#AGAnUtOq4 ... MtAmqxke1Y
Thanks in advanced
Thanks in advanced
keydb_helper
Hey Warbington, thanks for the new disc dump. The B702 variant of The Innkeepers has been added to the public keydb.
Thanks for the new disc dump Toad King. The C9AE variant of Get Carter has been added to the public keydb.Toad King wrote: Thu Aug 28, 2025 10:08 pm Dump for Get Carter (MKB20_v82_Get_Carter_-_4K_UHD_C9AE)
Hey NotThatGuy, thanks for the disc dumps. The 56F6 variant of The Lords of Discipline and the A012 variant of This Is Spinal Tap have been added to the public keydb.NotThatGuy wrote: Fri Aug 29, 2025 12:19 am Hi,
The lords of discipline: ...
This is spinal tap: ...
Thanks in advanced
Hey jemima, thanks for contacting nalor. Funnily enough I also PM'd nalor yesterday regarding that text encoding issue. I was only able to narrow the date down to after August 16 and before August 20. Hopefully the previous representation can be restored without too much hasslejemima wrote: Thu Aug 28, 2025 7:11 pm FYI: There was some mess up in the online DB on 2025-08-19... diff to the day before shows that for ~ 16670 entries, such encoding corruption happened... I've already PMed nalor about it.![]()
KeyDB Lower Priority Disc List
- The MKB_RO.inf file from the original disc is required
mattmak464
The Karate Kid Part II (1986) Dump:
MKB20_v77_Karate_Kid_Part_II_6936.tgz
https://drive.google.com/file/d/1QOEjDJ ... share_link
MKB_RO.inf
https://drive.google.com/file/d/1qvJUvs ... sp=sharing
MKB_RO.inf
keydb_helper
Hey mattmak464, thank you for the new disc dump. The 6936 variant of The Karate Kid Part II has been added to the public keydb.mattmak464 wrote: Fri Aug 29, 2025 3:50 am The Karate Kid Part II (1986) Dump:
MKB_RO.inf
To save you the trouble in the future, you can skip supplying the MKB_RO.inf file when your disc dump TGZ file is larger than 3-4MB.
mattmak464
The Karate Kid Part III (1989) Dump:
MKB20_v77_Karate_Kid_Part_III_B244.tgz
https://drive.google.com/file/d/1gASC_5 ... sp=sharing
MrPenguin
It has been observed that you would only need to provide the MKB_RO.inf as well if the dump's variant code is odd, i.e. ending in 1, 3, 5, 7, 9, B, D, or F.keydb_helper wrote: Fri Aug 29, 2025 3:57 am To save you the trouble in the future, you can skip supplying the MKB_RO.inf file when your disc dump TGZ file is larger than 3-4MB.
keydb_helper
Thanks mattmak464, the B244 variant of The Karate Kid Part III has been added to the public keydb.mattmak464 wrote: Fri Aug 29, 2025 3:59 am The Karate Kid Part III (1989) Dump:
Thanks for the reminder, I'll update the original postMrPenguin wrote: Fri Aug 29, 2025 10:37 am It has been observed that you would only need to provide the MKB_RO.inf as well if the dump's variant code is odd, i.e. ending in 1, 3, 5, 7, 9, B, D, or F.
bdjvm
mkb20_v82_uhd_die_akte_maldoror_47b8.tgz
https://www.mediafire.com/file/2lgug7x0 ... 8.tgz/file
Thanks.
Thanks.
keydb_helper
Thanks for the disc dump. The 47B8 variant of Die Akte Maldoror has been added to the public keydb. Interestingly it shares a media key with S3D5 from the recent Knight Rider boxset. I think we've seen at least 4-5 similar instances now.
jackycyk0924
Hello, here is the tgz dump file (v82) for a Japanese concert BD:
https://drive.google.com/file/d/1Av2_Lf ... 3iIOV/view
I also sent the tgz file to the email: svq@makemkv.com
Would be very grateful if you could add it to keydb.cfg. Thanks!
bdjvm
Thank you, it works. Another dump:
MKB20_v82_JURASSIC_WORLD_REBIRTH_9334.tgz
https://www.mediafire.com/file/vuawwlcg ... 4.tgz/file
AlluS
