Public KeyDB Disc Submissions
rusty100
Kill List (2011) Severin UHD
MKB20_v82_KILL_LIST_UHD_7D8E.tgz
via WH16NS60
https://drive.google.com/file/d/1wmGdC4 ... sp=sharing
via WH16NS60
keydb_helper
Thanks for the disc dump JIM7S. The 7A72 variant of Lilo and Stitch has been added to the public keydb.
Hey chucky527c, the E6A0 variant of But I'm a Cheerleader has been added to the public keydb.chucky527c wrote: Tue Aug 26, 2025 11:27 pm But I'm a Cheerleader
MKB20_v82_But_I'm_a_Cheerleader_(Director's_Cut)_E6A0
Hey creon, this thread is intended for posting links to disc dump files.
Hey rusty100, thanks for the new disc dump. The 7D8E variant of Kill List has been added to the public keydb.rusty100 wrote: Wed Aug 27, 2025 3:21 am Kill List (2011) Severin UHD
via WH16NS60
KeyDB Lower Priority Disc List
- The MKB_RO.inf file from the original disc is required
KingGeedorah
Yes I guess I didn't mention I did clean it and it looked good obviously like everyone says it could have something tiny i can't see or notice but i'm not sure what to do if i've already attempted to clean it three times. Also yes KeyDB.cfg is in the right spot because it allows me to rip other blu rays it's just the 4k Coraline that has issue. The log window does tell me my AACS access has probably been revoked but if that were the case I feel my other blu rays wouldn't work but they do. Considering its just this one movie I think it's safe to assume its the disc.MartyMcNuts wrote: Tue Aug 26, 2025 10:04 amDid you clean the disc? Doesn't matter if it appears to be pristine, give it a clean!KingGeedorah wrote: Tue Aug 26, 2025 9:03 amAwesome info, that honestly helps narrow down some troubleshooting now. Now I guess I need to find out why the properly flashed drive isn't working because every other disc i've had works and this one definitely doesn't have any marks or problems by my own eye sight. All my leads seem to be either something wrong with my disc or my drive. Sorry for all the extra posts if it's bogged this thread down I'm just going to buy another copy of the movie and see if it is the disc because I read someone else having issues with Contenthash002.tbl stopping the rip found themselves to have a defective disc and a new one worked.MartyMcNuts wrote: Tue Aug 26, 2025 8:06 am
You don't search KeyDB for the variant, you search for the DiscID, which is the SHA-1 of the Unit_Key_RO.inf file in the AACS folder on the disc (or in the dump file). Your DiscID is EE4F9E886AC5E85E9DB4DCD00712776869D690B3 and there is already a record for this disc in the KeyDB.
You did extract the KeyDB.cfg file from the zip in to your MakeMKV data directory (where the dumps go), right??
What does the MakeMKV log window say?
Here is the last bit of the log window on attempting to rip the blu ray.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:1'
DEBUG: Code 0 at :7BN0KcFt[_f`wgGpG:121264395
DEBUG: Code 4 at :7BN0KcFt[_f`wgGpG:213130789
Saved AACS dump file as /home/bradley/.MakeMKV/MKB20_v77_Coraline_E97B.tgz
DEBUG: Code 0 at !_"3Fn0b[mhvtTs$:213132721
DEBUG: Code 0 at !_"3Fn0b[mhvtTs$:213131341
KingGeedorah
So In the MakeMKV application if it tells me libredrive is enabled could it be wrong? It 100% shows it's enabled and works on other blu rays perfectly fine so I feel it should be fine. I can try to look and see about the write access but I once again assume i have write access because it works flawlessly aside from this disc.MrPenguin wrote: Tue Aug 26, 2025 10:49 amEverything points to your drive not having enabled LibreDrive, which means that bus encryption is still active. Note that your log.txt file does not contain a line like:KingGeedorah wrote: Tue Aug 26, 2025 9:03 am Now I guess I need to find out why the properly flashed drive isn't working because every other disc i've had works and this one definitely doesn't have any marks or problems by my own eye sight. All my leads seem to be either something wrong with my disc or my drive.Do you have write-access to your UHD drive's /dev/sgX device? (Where X is a number such as 0, 1, 2 etc.) E.g. something like:Code: Select all
001011:0000 Using LibreDrive mode (v06.3 id=1F08FC37E75B)where the non-root user running MakeMKV belongs to the cdrom group.Code: Select all
0 crw-rw----+ 1 root cdrom 21, 1 Aug 26 06:05 /dev/sg1
Here is what it says about my drive information
Firmware version: 1.03
keydb_helper
Your disc is fine and it is already supported by the public keydb.KingGeedorah wrote: Wed Aug 27, 2025 5:05 am ...
LibreDrive being functional is a strict requirement for UHD (AACS 2.0) Blu-ray support in MakeMKV. Non-UHD Blu-ray discs do not presently require LibreDrive to be functional.
It is important to understand the distinction between a particular drive firmware being capable/compatible with LibreDrive and LibreDrive actually being active and usable.
This issue is seen quite commonly on BU40N 1.03MK and certain other MK firmware releases on Linux. The same drive/firmware combinations work perfectly on macOS and Windows but there is a compatibility issue on certain Linux distros. If you downgrade your drive to the BU40N 1.00 firmware you should be fine.
As I mentioned above, AACS 1.0 (1080p) Blu-ray discs do not currently require LibreDrive. It would be nice if the MakeMKV status panel made a distinction between a firmware being supported by LibreDrive and LibreDrive actually being active and functional but it is an edge case.KingGeedorah wrote: Wed Aug 27, 2025 5:16 am So In the MakeMKV application if it tells me libredrive is enabled could it be wrong? It 100% shows it's enabled and works on other blu rays perfectly fine so I feel it should be fine. I can try to look and see about the write access but I once again assume i have write access because it works flawlessly aside from this disc.
If you'd like to continue discussing your Linux & BU40N 1.03MK issue please create a new thread in the Linux subforum. I get notification emails for this thread and this topic isn't related to the public keydb.
cjw73
red_demon_wizard
Seventh Seal Criterion 4K (seems like it should be there, but disc could not be decrypted)
https://drive.google.com/file/d/1X3Jyg1 ... sp=sharing
quaytsar
It wasn't when I re-downloaded it 5 minutes ago.keydb_helper wrote: Sat Aug 23, 2025 3:04 amHey quaytsar, the A86E variant of A Knight's Tale has been added to the public keydb.quaytsar wrote: Fri Aug 22, 2025 11:40 pm Dump of A Knight's Tale 4K Korean disc. Let me know if the link doesn't work.
MKB20_v77_Knight's_Tale,_A_A86E
keydb_helper
Thanks for the disc dump cjw73. The DE14 variant of Tornado has been added to the public keydb.
Hey red_demon_wizard, the B517 variant of Seventh Seal has been added to the public keydb. In the future please remember to include the MKB_RO.inf file when your disc dump file is less than 3MB in size.red_demon_wizard wrote: Wed Aug 27, 2025 4:40 pm Seventh Seal Criterion 4K (seems like it should be there, but disc could not be decrypted)
What link did you use to download the public keydb? I just double checked and your disc has definitely been included since August 22/23. If you open up the keydb.cfg file with a text editor you should be able to find this line (truncated to avoid posting disc keys to the forum):
0x8AE98D1E809B49BBED8162DB77A14EAFA9324205 = KNIGHTS_TALE_A (Knight’s Tale, A - 4K Ultra HD) | D | 2025-03-27 | M | ...
quaytsar
I used the link from your comment: http://fvonline-db.bplaced.net/. I downloaded "keydb.cfg - Language English (34638 entries)" at "LastUpdate: 2025-08-28 02:43"ish I know how to extract the config file into MakeMKV's data directory.keydb_helper wrote: Thu Aug 28, 2025 1:14 amWhat link did you use to download the public keydb? I just double checked and your disc has definitely been included since August 22/23. If you open up the keydb.cfg file with a text editor you should be able to find this line (truncated to avoid posting disc keys to the forum):If you can't see that line, follow my instructions hereCode: Select all
I was searching "Knight's Tale" before, but it didn't show up. Searching the hexcode, I found
0x8AE98D1E809B49BBED8162DB77A14EAFA9324205 = KNIGHTS_TALE_A (Knight’s Tale, A - 4K Ultra HD) | D | 2025-03-27 | M |-
keydb_helper
Good to hear!quaytsar wrote: Thu Aug 28, 2025 3:04 am I used the link from your comment: .... I downloaded "keydb.cfg - Language English (34638 entries)" at "LastUpdate: 2025-08-28 02:43"ish I know how to extract the config file into MakeMKV's data directory.
Searching for the disc ID is always preferable. You can calculate it yourself by using a tool like 7-zip to generate the SHA-1 hash of the Unit_Key_RO.inf file in the AACS directory on your disc.quaytsar wrote: Thu Aug 28, 2025 3:04 am I was searching "Knight's Tale" before, but it didn't show up. Searching the hexcode, I found, but MakeMKV kept giving a volume key not found error until I extracted the key myself and manually added it. Searching shows it is the exact same key as is already in there (| U | 1-0xD000D...), but MakeMKV wasn't finding it. No idea wtf was wrong. ¯\_(ツ)_/¯Code: Select all
I think MakeMKV may have tripped up on the disc metadata title. KeyDB records are formatted like this:
<Disc ID Hash> = <UDF Volume Label> (<Optional Disc Metadata Title>) | D | <Disc Date>...
Only 2-3 known UHD discs contain this character in their metadata title. So if this is indeed the cause it isn't too surprising we haven't noticed it until now.
neo14
I have these errors trying to rip Ocean's Eleven trilogy (firts part) Italian Steelbook:
Error 'Error de SCSI - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' leyendo '/BDMV/STREAM/00002.m2ts' en la posición '49280901120'
Error 'Error de S.O. - STATUS_DEVICE_DATA_ERROR' leyendo '\Device\CdRom1' en la posición '49280901120'
I tried to clean the disk, in 2 differents computers and differents hard disks
Any idea?
Any idea?
MrPenguin
Then you must be posting in the wrong thread, because your decryption key has clearly already been calculated.neo14 wrote: Thu Aug 28, 2025 11:01 am I have these errors trying to rip Ocean's Eleven trilogy (firts part) Italian Steelbook:
Rey111
I receive an error trying to view or rip Sinners 4k French Steelbook . Someone can kindly help . Thanks
neo14
In which thread I should be poste it?MrPenguin wrote: Thu Aug 28, 2025 1:11 pmThen you must be posting in the wrong thread, because your decryption key has clearly already been calculated.neo14 wrote: Thu Aug 28, 2025 11:01 am I have these errors trying to rip Ocean's Eleven trilogy (firts part) Italian Steelbook:
