Pavements 4K dump submitted
Puff Diesel
#1 Post by Puff Diesel » Tue Aug 26, 2025 5:11 pm
Just received the Pavements 4K UHD and it won't load. I updated MakeMKV and added the keydb.cfg file and no luck. The drive I'm using is an LG BP60NB10.
I just submitted the dump file. Here is a link in case anyone can help: https://drive.google.com/file/d/1wHuVGB ... drive_link
Thanks!!
MrPenguin
Re: Pavements 4K dump submitted
#2 Post by MrPenguin » Tue Aug 26, 2025 6:55 pm
Puff Diesel wrote: Tue Aug 26, 2025 5:11 pm Here is a link in case anyone can help:
Can you adjust the "Share" option for that file please, so that people can access it?
Puff Diesel
#3 Post by Puff Diesel » Tue Aug 26, 2025 8:54 pm
Done.
Thanks!!
MrPenguin
#4 Post by MrPenguin » Tue Aug 26, 2025 9:45 pm
Puff Diesel wrote: Tue Aug 26, 2025 5:11 pm Just received the Pavements 4K UHD and it won't load. I updated MakeMKV and added the keydb.cfg file and no luck. The drive I'm using is an LG BP60NB10.
Your drive has not enabled LbreDrive, and so MakeMKV could not disable bus encryption. Perhaps someone can advise you about your drive's firmware?
SDF  v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM03M7F44210
However, KEYDB.cfg does already contain your disk's key, and so MakeMKV should be able to rip it once you have enabled LibreDrive.
Puff Diesel
#5 Post by Puff Diesel » Wed Aug 27, 2025 12:01 am
Thanks! I did some research, activated Libre and it seems that worked. Appreciate the help!!
