Just received the Pavements 4K UHD and it won't load. I updated MakeMKV and added the keydb.cfg file and no luck. The drive I'm using is an LG BP60NB10.
I just submitted the dump file. Here is a link in case anyone can help: https://drive.google.com/file/d/1wHuVGB ... drive_link
Thanks!!
Pavements 4K dump submitted
MrPenguin
Re: Pavements 4K dump submitted
Can you adjust the "Share" option for that file please, so that people can access it?
Puff Diesel
Done.Can you adjust the "Share" option for that file please, so that people can access it?
Thanks!!
MrPenguin
Your drive has not enabled LbreDrive, and so MakeMKV could not disable bus encryption. Perhaps someone can advise you about your drive's firmware?Puff Diesel wrote: Tue Aug 26, 2025 5:11 pm Just received the Pavements 4K UHD and it won't load. I updated MakeMKV and added the keydb.cfg file and no luck. The drive I'm using is an LG BP60NB10.
SDF v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM03M7F44210-
Puff Diesel
Thanks! I did some research, activated Libre and it seems that worked. Appreciate the help!!
