submitted 8/26/25
MKB20_v82_But_I'm_a_Cheerleader_(Director's_Cut)_E6A0.tgz
But I'm a Cheerleader 4k dump submitted
MrPenguin
Re: But I'm a Cheerleader 4k dump submitted
Could you also upload this TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file as well.
Kaik541
I was going to do that but according to the page, Pioneer drives are not supported for the keydb.cfg method
I do in fact use a pioneer drive (from billy), so I'm not sure if the dump will be helpful
if it would be, let me know and I can still upload it
Some Pioneer models do produce usable dumps. If your drive is not a 209, UD03 or UD04, the dump may be usable.Kaik541 wrote: Thu Aug 28, 2025 12:37 am I was going to do that but according to the page, Pioneer drives are not supported for the keydb.cfg method
Kaik541
MrPenguin
Kaik541
I had tried a few days ago and it failed, but it's working now. Confirmed.
