Pavements 4K dump submitted
Puff Diesel
Post by Puff Diesel »
Just received the Pavements 4K UHD and it won't load. I updated MakeMKV and added the keydb.cfg file and no luck. The drive I'm using is an LG BP60NB10.
I just submitted the dump file. Here is a link in case anyone can help: https://drive.google.com/file/d/1wHuVGB ... drive_link
Thanks!!
MrPenguin
Re: Pavements 4K dump submitted
Post by MrPenguin »
Puff Diesel wrote:
Tue Aug 26, 2025 5:11 pm
Can you adjust the "Share" option for that file please, so that people can access it?
Puff Diesel
Done.
Thanks!!
MrPenguin
Post by MrPenguin »
Your drive has not enabled LbreDrive, and so MakeMKV could not disable bus encryption. Perhaps someone can advise you about your drive's firmware?
SDF  v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212107081556_SIM03M7F44210
However, KEYDB.cfg does already contain your disk's key, and so MakeMKV should be able to rip it once you have enabled LibreDrive.
Puff Diesel
Thanks! I did some research, activated Libre and it seems that worked. Appreciate the help!!
