Public KeyDB Disc Submissions
Post by SamuriHL »
Coopervid wrote:
Fri Aug 22, 2025 6:28 pm
SamuriHL wrote:
Fri Aug 22, 2025 6:08 pm
cjw73 wrote:
Fri Aug 22, 2025 9:43 am
that's a nice util you made there :) helps to add the new stuff to the database file when a key is added
It's mostly just a pretty UI for FindVUK. Nalor did us all a favor with that one but the problem I was trying to solve with my front end was syncing the keydb to MakeMKV. The Disc Info function is useful for seeing what the status of your disc is in the keydb without having to manually do anything. I find it useful for my own discs to know what's supported and what isn't. And since people tend to get discs WAY sooner than I do by the time mine arrive they're almost all already in the keydb. lol
Sam, I suggest that the initial post should be edited and Windows users should be motivated / encouraged to use your tool frequently to avoid circumstances like those. @keydb_helper.
That's up to keydb_helper as this is their thread. But I think if more people used my tool to check their discs it might help people get their discs working faster and cut down on duplicate dump submissions. I don't want to clutter up this thread too much with discussion of my tool, though, as it's really theirs to help people with their discs.
quaytsar
Post by quaytsar »
Dump of A Knight's Tale 4K Korean disc. Let me know if the link doesn't work.
MKB20_v77_Knight's_Tale,_A_A86E
https://1drv.ms/u/c/f88191cbd757eb3e/Ec ... w?e=wlXJs7
keydb_helper
Post by keydb_helper »
mich52 wrote:
Fri Aug 22, 2025 5:29 pm
Death Wish 5863
Thank you.
Hey mich52, thank you for including your MKB_RO.inf file. The 5863 variant of Death Wish has been added to the public keydb.
buffalobossie wrote:
Fri Aug 22, 2025 5:40 pm
Some new UHDs from Vinegar Syndrome:
Sgt Kabukiman NYPD - ...
Mixed Blood - ...
Habit - ...
No Telling - ...
Hey buffalobossie, thanks for the new disc dump files. Your discs have been added to the public keydb. Oddly the media keys for your discs are shared with a few season 1 & 2 discs from the recent Knight Rider box set.
SamuriHL wrote:
Fri Aug 22, 2025 7:49 pm
Good idea, I'm happy to update the initial post to make the link to SamuriHL's tool more prominent.
quaytsar wrote:
Fri Aug 22, 2025 11:40 pm
Hey quaytsar, the A86E variant of A Knight's Tale has been added to the public keydb.
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
KingGeedorah
Post by KingGeedorah »
Dump of Coraline 4K Steelbook I see other posts and in the spreadsheet but this version doesn't seem to be on any list or my disc is messed up.
MKB20_v77_Coraline_E97B.tgz
MrPenguin
Post by MrPenguin »
KingGeedorah wrote:
Sat Aug 23, 2025 6:19 am
Your disk is probably fine, and already has a validated entry in KEYDB.cfg. I suspect your real problem is that your drive hasn't enabled LibreDrive yet:
SDF  v098: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_MOEN1SK3030
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:1'
DEBUG: Code 0 at |X'!q)-CE\{1Wk3sR:213130306
001003:0020 DEBUG: Code 0 at :7BN0KcFt[_f`wgGpG:121264395
001003:0020 DEBUG: Code 4 at :7BN0KcFt[_f`wgGpG:213130789
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Also, the MKB_RO.inf file you have provided separately is only 56 bytes long, and so contains no useful information. The AACS/MKB_RO.inf file from your physical UHD disk would be far more useful.
Chelesty
Post by Chelesty »
First post on the forum, hope this dump is sufficient:
https://drive.google.com/file/d/1mJdsrE ... sp=sharing
Sinners 4K Steelbook EU. MakeMKV wouldn't decrypt the disc, even with public keydb.cfg. So I thought I'd drop this on here.
nobodynothingnowhere
Post by nobodynothingnowhere »
nobodynothingnowhere wrote:
Wed Aug 20, 2025 3:39 am
Hi, if it's possible to add these JP blurays I would be very grateful.
MKB_v82_SLFV064_26AC.tgz
https://tmp.link/f/68a541a6ad067
MKB_v82_NPBD_2505_1_67D2.tgz
https://tmp.link/f/68a542b94f79e
Thank you for adding these! Unfortunately, the bluray associated with MKB_v82_SLFV064_26AC.tgz is still unable to be read. (I'm getting the "This disc uses newer version of AACS protection." error.) Is this related to the keyDB or something separate?
KingGeedorah
MrPenguin wrote:
Sat Aug 23, 2025 2:38 pm
I'll update to the proper MKB_RO.inf file and I would love to know what more i can do for the LibreDrive because i followed everything I found and got it flashed/patched to work on all my other blu rays.
Here is a screenshot of my MakeMKV screen for my drive it shows its been patched and everything. I looked through the file for KEYDB.cfg but never found key/listing for a Coraline 4K with the same date or tag of E97B unless i'm just looking in the wrong place.
Screenshot:
https://drive.google.com/file/d/1WekVpJ ... jSZm6/view
Same link for new MKB_RO.inf
Uploaded
MrPenguin
Post by MrPenguin »
Sat Aug 23, 2025 9:14 pm
Have you checked whether the download link for this TGZ dump file works?
MrPenguin
Post by MrPenguin »
KingGeedorah wrote:
Sat Aug 23, 2025 9:39 pm
Only The Powers That MakeMKV know how LibreDrive actually works, but it does seem that sometimes it just fails to enable. And the only thing to do is to try again.
And for some unfathomable reason, the link which you claim is for your MKB_RO.inf file is actually for someone else's "Sinners" TGZ dump file.
keydb_helper
Chelesty wrote:
Sat Aug 23, 2025 8:19 pm
First post on the forum, hope this dump is sufficient: ...
Hey Chelesty, thanks for the new disc dump. The 07E4 variant of Sinners has been added to the public keydb.
KingGeedorah
MrPenguin wrote:
Sat Aug 23, 2025 11:41 pm
Yeah I had scrolled up and copied the first google drive link thinking i grabbed the one I posted, it's properly this link. I guess i can try to repatch/reflash the drive which sucks.
ckdals103
AACS v82 dump - Japanese Blu-ray (AVXK_43553)
Post by ckdals103 »
I couldn’t decrypt this Japanese Blu-ray disc (AACS v82).
Please find attached the dump file generated by MakeMKV for your reference.
Disc label: AVXK_43553
Thanks a lot for your support!
MrPenguin
Post by MrPenguin »
KingGeedorah wrote:
Sun Aug 24, 2025 5:28 am
I doubt you would need to reflash the drive! I only meant power-cycle it, and then re-insert the disk :).
skl49
Post by skl49 »
Hello, I am unable to decrypt this japanese BD using keydb.cfg.
This is my dump file:
https://drive.proton.me/urls/J6S8Y7CBT8#cC8nBX9Ct6wo
Thank you
