I'm experiencing an issue with a Blu-ray disc that uses a newer version of AACS protection. MakeMKV was unable to decrypt the disc and generated a dump file. I'm attaching the file here for your review:
Filename: MKB_v81_AVXK_43241_FADC.tgz
Thank you for your support!
AACS Dump for Unsupported Disc – MKB_v81_AVXK_43241_FADC
nourh
MrPenguin
Re: AACS Dump for Unsupported Disc – MKB_v81_AVXK_43241_FADC
No, MKBv81 is not a newer version of AACS protection. I am surprised that MakeMKV cannot read your disk, because it has supported MKBv81 for ages. Could you upload your TGZ dump file into (say) OneDrive or Google Drive, and then reply with a public download link please? This would allow people to try adding your disk to the public KEYDB.cfg file.nourh wrote: Wed Aug 20, 2025 6:29 pm I'm experiencing an issue with a Blu-ray disc that uses a newer version of AACS protection. MakeMKV was unable to decrypt the disc and generated a dump file. I'm attaching the file here for your review:
nourh
Thank you for your support. I’ve uploaded five TGZ dump files related to MKBv81 and MKBv82 discs.
Here is the public download link: https://drive.google.com/drive/folders/ ... sp=sharing
I hope this helps with updating the KEYDB.cfg file. Please let me know if you need anything else.
