LOTR TT 4k (disc 2) & POTC OST 4k wont open
Nixxy
#1 Post by Nixxy » Tue Aug 19, 2025 10:18 pm
Hi!
Found 2 discs in my collection so far that i wasn't able to dump!. Log files attached.
I'm new to the forum so sorry if I'm reporting these discs wrong!
Any ideas if there is a solution to this?
Re: LOTR TT 4k (disc 2) & POTC OST 4k wont open
#2 Post by MartyMcNuts » Tue Aug 19, 2025 11:20 pm
Nixxy wrote: Tue Aug 19, 2025 10:18 pm Hi!
There's nothing attached. You can copy and paste the MakeMKV log window here.
Does the log say volume key unknown for this disc? Does a tgz dump file get generated? If so, you should email that tgz dump file to svq@makemkv.com. Additionally, you can host that dump file somewhere and provide a download link so that a record may be added to the public KeyDB.
If you are just getting read errors while ripping, the first thing to always try is cleaning the disc!
Nixxy
#3 Post by Nixxy » Wed Aug 20, 2025 7:29 am
Hi again!
So sorry i though the files got uploaded! Here are a link to the 2 .tgz files for both movies!
Link: https://1drv.ms/f/c/308e7c0bdd890800/En ... w?e=Zyh6X4
Both of them give me the "The volume key is unknown for this disc - video can't be decrypted" error message!
I'll send them to the email you recommended in your reply too, thank you! :)
MrPenguin
#4 Post by MrPenguin » Wed Aug 20, 2025 3:23 pm
Nixxy wrote: Wed Aug 20, 2025 7:29 am So sorry i though the files got uploaded! Here are a link to the 2 .tgz files for both movies!
FYI you also appear to be using a Verbatim 43888 drive containing a Pioneer BDR-UD04 device, and so your dumps aren't very useful to The Powers That KEYDB. However, it looks like the KEYDB.cfg file already contains validated entries for both your disks anyway.
