You have to wait until Mike comes up with a solution for that.GmanEst72 wrote: Mon Aug 18, 2025 8:50 am Hi,
Wondering if anyone can help. A friend has just gave me a drive he didn't need any more, MakeMKV info below.
I think he my have flashed to the pioneer newest firmware showing 3.11, not sure if it can be done.
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.11
Serial number: ****************
Firmware date: 2023-03-03
Highest AACS version: 77
Drive platform: Pioneer RS8232
Firmware version: ID34
Pioneer BDR-XD05TS 4k compatibility?
Re: Pioneer BDR-XD05TS 4k compatibility?
Cheer for that, as soon I seen the info had an idea it could not be done at the moment.
Probably why he gave it to me.
Thank you
Thank you
Sadly he updated it before giving it to you and now it can't do UHDGmanEst72 wrote: Mon Aug 18, 2025 8:50 am Hi,
OS device name: H:
Revision: 3.11
Mike has assured us that all UHD-capable Pioneers will eventually support LibreDrive. However, today is not yet that day...Billycar11 wrote: Mon Aug 18, 2025 1:37 pm Sadly he updated it before giving it to you and now it can't do UHD
I did see Mike's post after I posted this, however thought it was worth asking. As I mentioned before that's why he probably gave it to me
Let's hope Mike can sort something out.
Thank you so much, it worked.Coopervid wrote: Sun Aug 17, 2025 6:57 pmPM sent.K3ks3r wrote: Sun Aug 17, 2025 6:27 pm Hi, my Asus 5.25 BW-16D1HT is starting to have issues with some disks. I have found an old BDR-XD05 drive, is it possible to make it UHD compatible?
Help would be appreciated. ThanksCode: Select all
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-XD05 Revision: 3.10 Serial number: RGDL009194WL Firmware date: 2017-06-22 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Enabled Drive platform: RS8232 Firmware name: PIONEER BDR-XD05 Firmware type: Original (unpatched) Firmware version: 3.10/ID34 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes![]()
OS device name: E:
Current profile: DVD-ROM
Revision: 1.20
Serial number: redacted
Firmware date: 2013-11-11
Drive platform: RS8231
Firmware version: 1.20/ID69
Can this be improved? It doesn't read very well anyway. Thanks.
OS device name: E:
Revision: 1.20
PM sent for UHD. Clean your laser lens!!comadose wrote: Sun Sep 21, 2025 2:35 pm Drive Information
OS device name: E:
Revision: 1.20
Thank you very much.
Hi, thank you for such a great resource - please could you let me know if it's possible to update the following drive? Thanks
Revision: 1.21
Serial number: ###
Firmware date: 2014-04-02
Firmware version: 1.21
Revision: 1.21
Serial number: ###
Sure just email me that info see belowDukeUK wrote: Sat Oct 04, 2025 1:59 pm Hi, thank you for such a great resource - please could you let me know if it's possible to update the following drive? Thanks
Revision: 1.21
Serial number: ###
Hello @Coopervid,
I was looking to pruchase a new BD drive to replace my very old Pioneer one (and backup UHD discs). Then, I stumbled upon this thread, that made me think that maybe my old drive still had some potential…
Do you think anything could be done with this?
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 82
Firmware version: 3.01/ID34
And if not, what would be your recommendation for a good model to buy, currently available, that could work out of the box (and be used with a mac).
Thanks a lot!
Revision: 3.01
Serial number:
Thanks a lot!
PM sent.Duranceau wrote: Sun Jan 18, 2026 1:49 pm Hello @Coopervid,
Revision: 3.01
Serial number:
Thanks a lot!
Hi @Coopervid,
I also have one of these drives. Can this be updated to support 4k UHD?
Revision: 3.01
Serial number: #####
Revision: 3.01
Hi @Coopervid, you PMed me some details, but for the '07 drive, not the '05 drive. I can't seem to reply to your PM. Would you mind contacting me? Thanks.
