The website only supports HTTP, but some browsers (i.e. Chrome) always try using HTTPS instead. In which case, you would need to force your browser to use HTTP for this site.Mike_94 wrote: ↑Sat Aug 16, 2025 10:53 amThank you for your answer! I went to your linked page. In this post, it says I have to download the db from http://fvonline-db.bplaced.net/ (Direct link). But somehow I can't reach this page. It always says it cannot be found?Have you another link or some other method to get this db file? Thank you so much man!
Public KeyDB Disc Submissions
dracoola666
I’m submitting a key dump for a standard (non-UHD) Blu-ray and wasn’t sure if non-UHD titles are accepted here. Any advice would be appreciated.
MKB_v82_Haus_Geisterhuegel_D312.tgz
https://drive.google.com/file/d/12zP5dD ... drive_link
Can you adjust the "Sharing" option on that file please, so that everyone can access it?dracoola666 wrote: ↑Sat Aug 16, 2025 7:01 pmI’m submitting a key dump for a standard (non-UHD) Blu-ray and wasn’t sure if non-UHD titles are accepted here. Any advice would be appreciated.
dracoola666
Done. MakeMKV failed to rip this BD. thx and greetsMrPenguin wrote: ↑Sat Aug 16, 2025 7:27 pmCan you adjust the "Sharing" option on that file please, so that everyone can access it?dracoola666 wrote: ↑Sat Aug 16, 2025 7:01 pmI’m submitting a key dump for a standard (non-UHD) Blu-ray and wasn’t sure if non-UHD titles are accepted here. Any advice would be appreciated.
I’m sharing the dump file of a Japanese disc.
It's not a UHD disc, so I also attached the MKB_RO.inf file.
Hope you can help.Thank you!
javicozarcastillo
Thanks!!!
Thank you!keydb_helper wrote: ↑Fri Aug 15, 2025 3:30 pmHey MKVDUDE, thanks for the new disc dump file. The B03C variant of Scum has been added to the public keydb.
Novaboogie
Submitting the dump for Pirates of the Caribbean, Curse of the Black Pearl (5F0F variant)
https://www.dropbox.com/scl/fi/x5qpcdr2 ... ycaef&dl=0
is one of a 5 disk set, the only one of the 5 where 'the volume key is unknown'.
dracoola666
Works with the newest keydb. thx to the unknown peopledracoola666 wrote: ↑Sat Aug 16, 2025 7:01 pmHi,
nobodynothingnowhere
Hi, if it's possible to add these JP blurays I would be very grateful.
MKB_v82_SLFV064_26AC.tgz
https://tmp.link/f/68a541a6ad067
MKB_v82_NPBD_2505_1_67D2.tgz
https://tmp.link/f/68a542b94f79e
The Accountant 2 UHD
MKB20_v82_The_Accountant_2_02D2
https://wormhole.app/D1KpoJ#T-2wcuc3HhPrcVVN5vj61A
Here's the dump for The Conjuring UHD:
Thank you.
Thank you.
keydb_helper
Thanks to everyone for the new disc dump files. Every disc submitted today has been added to the public keydb.
