Poltergeist 4K Dump submitted
javicozarcastillo
#1 Post by javicozarcastillo » Tue Aug 12, 2025 5:10 pm
dump submitted on Poltergeist UHD Spanish Edition.
Thanks.
MrPenguin
Re: Poltergeist 4K Dump submitted
#2 Post by MrPenguin » Tue Aug 12, 2025 9:45 pm
javicozarcastillo wrote: Tue Aug 12, 2025 5:10 pm dump submitted on Poltergeist UHD Spanish Edition.
If this doesn't work, could you upload your TGZ dump file into (say) OneDrive or Google Drive please, and then reply with a public download link? This would allow people to try adding your disk to the public KEYDB.cfg file.
javicozarcastillo
#3 Post by javicozarcastillo » Wed Aug 13, 2025 2:16 pm
Yes, I've tried, and it's not working. This is the link to the TGZ dump file, as you request:
https://drive.google.com/file/d/1SfUar8 ... sp=sharing
Hope someone could help me.
Thanks in advance,
Javi
javicozarcastillo
#4 Post by javicozarcastillo » Wed Aug 13, 2025 2:31 pm
I don't know if it helps, but inside latest KEYDB.cfg I found these:
0x5F42B478EEA764438B44702E0018D4FCC497998F = POLTERGEIST [Poltergeist (1982) - 4K Ultra HD] | D | 2022-07-29 | U | 1-0xF709D194A475FE6D2D970B178827022C ; MKBv76/BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
0x2B3A6AF6246224FACB414316722FA7D3E425A459 = POLTERGEIST [Poltergeist 4K Ultra HD] | D | 2022-07-29 | U | 1-0xF709D194A475FE6D2D970B178827022C ; BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
0x46FB504BF9473BE12164F7BFE3D355581D390B4E = POLTERGEIST [Poltergeist 4K Ultra HD] | D | 2022-07-29 | M | 0xA8E726C2955F431306309367F6AE00D8 | I | 0x9C5F3C7824FBDA6A2B9612B9A0981907 | V | 0xB8C28DC690FE0D6DD05213F23C1ABECA | U | 1-0xF709D194A475FE6D2D970B178827022C ; BEE (UHD) (LEGACY) (NOTVALIDATED) (BD)
2022-07-29 is exactly the timestamp of my UHD Blu-ray, so I understand that these refers to it. Not sure what it means "not validated", I guess maybe it has something to do with my problem, but again, I'm very lost in that garden. Any help will be appreciated....
javicozarcastillo
#5 Post by javicozarcastillo » Wed Aug 13, 2025 2:44 pm
I would also add that this is the only issue I had in a very long time. Recently I made backup copies of a lot of UHD Blu-rays without any single problem, so I understand thet the Blu-ray reader (ASUS BW-16D 1HT) is not part of the problem...
MrPenguin
#6 Post by MrPenguin » Wed Aug 13, 2025 2:47 pm
javicozarcastillo wrote: Wed Aug 13, 2025 2:31 pm I don't know if it helps, but inside latest KEYDB.cfg I found these:
The format of these entries is
<DISCID> = <VOLUME NAME> (<META TITLE>) | D | <date> | ... etc
where <DISCID> is the SHA1 hash of the disk's AACS/Unit_Key_RO.inf file. And MakeMKV can only use KEYDB entries which contain a "| V |" field anyway. So unless your own disk's ID matches 0x46FB504BF9473BE12164F7BFE3D355581D390B4E, I can understand why KEYDB isn't helping you atm. However, you have also provided your TGZ dump file and so there's a good chance that might now change.
I recommend using SamuriHL's Keydb Helper Tool (see link in my signature) to keep your local copy of KEYDB.cfg up-to-date, as this will save you from needing to re-download the entire ZIP file each time.
MrPenguin
#7 Post by MrPenguin » Wed Aug 13, 2025 2:50 pm
javicozarcastillo wrote: Wed Aug 13, 2025 2:44 pm I would also add that this is the only issue I had in a very long time. Recently I made backup copies of a lot of UHD Blu-rays without any single problem, so I understand thet the Blu-ray reader (ASUS BW-16D 1HT) is not part of the problem...
Yes, the problem is definitely that someone always needs to be the first to try decrypting a particular disk variant, and in this case that someone is you :D.
