The Eagle Shooting Heroes PROBLEM
snake670
Post by snake670 »
i have AACSV82 problem can't rip the Bluray
any help ?
MrPenguin
Re: The Eagle Shooting Heroes PROBLEM
Post by MrPenguin »
snake670 wrote:
Wed Aug 13, 2025 10:21 am
Do you have a TGZ dump file? Because if you do, you need to email it to svq@makemkv.com. And if you also upload it into (say) OneDrive or Google Drive and reply with a public download link then people can try to add your disk to the public KEYDB.cfg file as well.
snake670
Post by snake670 »
Thank you
no i don't have a dump file.
how can i have it ?
thank you
MrPenguin
Post by MrPenguin »
snake670 wrote:
Wed Aug 13, 2025 4:10 pm
MakeMKV generates a TGZ dump file automatically whenever it fails to decrypt a disk. It should tell you file dump's filename in the log output.
