Is Makemkv no longer working.
jimbo4691
Post by jimbo4691 » Tue Aug 12, 2025 4:11 pm
I have tried to no end to get the program to work again. Putting in the license number deleted the program and reinstalled it again (worked before) but for some reason now I can't use the program??? Any suggestions.
Re: Is Makemkv no longer working.
Post by Woodstock » Tue Aug 12, 2025 7:33 pm
If you registered prior to July 31, 2025, MakeMKV works just fine.
If you are still using the beta key to run it without registering, the last beta key expired July 31, 2025, and no new beta key or permanent key has been available since then. If you are still using the beta key, you must set your system date to a date prior to July 31, 2025, start the program, and then reset your system date.
MrPenguin
Post by MrPenguin » Tue Aug 12, 2025 9:57 pm
There is now a new BETA key, valid until the end of September 2025 :D.
jimbo4691
Post by jimbo4691 » Sat Aug 16, 2025 4:23 pm
Thanks You All!!!
