Is Makemkv no longer working.
jimbo4691
I have tried to no end to get the program to work again. Putting in the license number deleted the program and reinstalled it again (worked before) but for some reason now I can't use the program??? Any suggestions.
Re: Is Makemkv no longer working.
If you registered prior to July 31, 2025, MakeMKV works just fine.
If you are still using the beta key to run it without registering, the last beta key expired July 31, 2025, and no new beta key or permanent key has been available since then. If you are still using the beta key, you must set your system date to a date prior to July 31, 2025, start the program, and then reset your system date.
MrPenguin
There is now a new BETA key, valid until the end of September 2025Woodstock wrote: Tue Aug 12, 2025 7:33 pm If you are still using the beta key to run it without registering, the last beta key expired July 31, 2025, and no new beta key or permanent key has been available since then.
jimbo4691
Thanks You All!!!
